Question about Whirlpool ED2NHGXM Side by Side Refrigerator
Filled house with smoke.
It appears the relay or capacitor overheated (the area left of the compressor as viewed from the back) and started smoking quite a bit. There is some discoloration on the wire connecting plug. Before I have someone fix it I would just like to know what could cause the overheating (by the way, no breakers were tripped) as I'm not sure I can trust this product (its barely 4 years old) until I know why it happened...what would have happened if we had not been home? Thanks
  • Whirlpool Master
  • 16,841 Answers
There is an overload protection kit for that unit that was listed as a production alternate. YOu can install that to see if it helps. There is always risk when you use appliances. Compressors can go bad or the power can surge or interrupt and then you have an issue with too much current and things getting burned out.
Posted on Jun 09, 2017
  • 54 Answers
SOURCE: Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Posted on Feb 14, 2008
  • 1902 Answers
SOURCE: started smoking and fan is still running but not cooling. neither
You have a bad compressor that is the only thing that will make something smoke and not let anything stay cool
Posted on Feb 08, 2009
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
  • 410 Answers
SOURCE: fridge cooling shut down after noticing heavy dust on bottom coil
hey Bob I'm gonna steer you in a differnet direction. does you refrig have electronic controls or just plain ol adjustment knobs? If just plain ol adj knobs try turning the both knobs all the way off then all the way back on to the coldest setting. then firmly tap the knobs with the handle of a screwdriver or butter knife especially the one that actually has the off postiton. this is the thermostat and i'm thinkng it has gone bad on you. you mentioned that nothing was running so if the compressor relay was bad you would still hear fans running.
if this doesnt work I would need you to give me a model number off of the unit so I could point you in the right direction and help you do some continuity tests. thanks peyton
Posted on Mar 05, 2009
SOURCE: Whirlpool side-by-side melted relay.
Maytag (owned by Whirlpool since 2005) has issued a recall on the compressor relay due to fires. Whirlpool brands are not listed in the recall but it looks like they should be. The problem goes back to Jan 01 according to the Consumer Product Safety Comission.
Posted on Mar 12, 2009
2003 kia sedona Replaced the C/fan H2 relay switch ran fine a few mins then a loud rumble near the front fan and smoke appeared. Switched them back no sound / smoke but now the ac is blowing hot air
Im going to guess that the cooling fan went bad. Smoke is a pretty good indicator that something is no good. It make have blow fuses that also power the A/C compressor. The C/Fan 2 fuse is the one that the compressor uses as well.
Aug 14, 2015 | Kia Cars & Trucks
Overheating brakes
Possibly fitted wrong,,,,possibly calliper or slides seized,,,sticking badly
May 25, 2013 | Ford Expedition Cars & Trucks
Can a dryer heating element smoke if dryer is not running?
Something fried and is shorted. Unplug this unit right away. There are a few sensors on this that could have overheated as they failed causing this smoke and smell, but UNPLUG UNIT!!! Then look at what has fried.
Aug 31, 2012 | Whirlpool Dryers
Smoke from the back of the refridgerator when the compressor started. Model: FRIDGIDAIRE FRT18B4A 8-9 years old
Smoke is never good! unplug the power and look it could be the start capacitor its round and black usually mounted to the side of the compressor will have two wires connected to it, it will be in a spring clip on each end pry it out. Now if its good it could have a charge in it, once you get it out look at it and you will have your answer if its bad, there is a current relay that starts the comp. and then switches to the run winding it could be bad as well, it located on the side of the comp. with a stainless clip holding a oval black plastic or baklamp cover. You should see the burnt area by now, as long as the pins that the current relay and over load are connected to are good, not burnt off, there will be three pins. I would buy the cap, current relay and overload and you might just save the beast. The current relay and one wire off the overload push on and off the pins. Good luck Ho the Parts are not very expensive I just bought these for a ref. of my sons cost me whole sale $43.00 cheaper then a service call ha?
Jun 30, 2011 | Frigidaire FRT18B4A Top Freezer...
Amana ASD2626HEW. Smoke coming from Relay/Overload with start capacitor #PS2069268. Is this the problem or a symptom of some other problem? Will replacing this part solve problem?
If the windings in the compressor test good then you can go to the next step. Smoke is an indication of a short circuit. I will send you to a page that has information on how to test, Be Right Back, Sea Breeze
Apr 18, 2010 | Amana ASD2626HE Side by Side Refrigerator
Refrigerator Compressor smoke hot to touch
Yes this is a sign of a burn out or start relay or start capacitor defect you made the correct choice. If you need assistance let me know, Sea Breeze
Jul 02, 2009 | Refrigerators
Started smoking and fan is still running but not cooling. neither
Feb 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2NHGXM Side by Side Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
