Question about Canon FAXPHONE L170 Plain Paper Laser
Scanning office docs easily
Can you suggest an inexpensive self feeding scanner for office docs, Orders, Invoices etc. I dont want to use a Hand Scanner. Can the Cannon L170 be used as a scanner for this purpose ?
  • jibfree3 Oct 29, 2008
    Thank you
    I will check my machine and the software
    AF
    Genius:
  • 2,120 Answers
Yes, if it has a standard printer port. Software may have come with your machine or use PaperPort Scanning Software. It won't work if all that you have is a USB port.
Posted on Oct 25, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
How do i fix the automatic doc feeder, not working
Does it do anything? Did you try any of the suggestions below offered to others with auto feed problems? If none of those suggestions help you may want to reinstall your printer on your computer. Beyond that you may have to do single page scanning on the scanner.
Mar 03, 2015 | Canon Pixma MX410 All-In-One Printer
Hi a vertical line is in image scanned please tell me how to solve this problem thanks
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the scanner top (by pullung it near the area where you feed the paper to scan). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning!
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 14, 2011 | Fujitsu fi-5120C
When I scan a doc It comes up as a jpeg using my new sx425w I wish to convert to a word doc to alter text but I do not get the option wnen scanning.Do I have I he wrong machine.or can you advise how to...
you need to have ocr software to convert the text from a scanned image to readable text. try going to microsoft office website and downloading the software. can also try the scanner manufacturers website for it.
Jan 16, 2011 | Epson Office Equipment & Supplies
Fi-6140-Rollers keeps moving even when doc feeder is empty.
There may be a piece of paper stuck in the sensor area, the scanner assumes there is paper and it keeps working. Blow gently and remove all shreds of paper.
S. Mohan
Aug 09, 2010 | Fujitsu fi-6140C Document Scanner Flatbed...
Scanning from printer can't see any computers. says it needs the software. pc is able to print docs to the printer. when scanning says connection error - been trying for 3 days now uploaded all drivers to...
for normal scanning you can go to control panel and choose the option of scanner and camera wizard and do the scanning but it is good if you install the driver of printer which is contain the scanner software and give you more option of scanning.
have a nice day and dont forget to give rate please...
Feb 12, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Wont scan some checks and wont scan money orders
The software for your device has special security features programmed in that will recognize commonly counterfeited items.
This software will prevent unauthorized scanning of security documents like cashier's checks, money orders, United States currency, etc.
There is no way to remove this feature from your scanner's software. However, some software allows for very low resolution (100 DPI or less) scans of these documents.
You'll just have to experiment and see if you can scan these documents with your scanner at these lower resolutions.
Feb 04, 2010 | Vision Panini My X 60 Check Scanner
Canon scanner, when I scan and open doc in office word its all jumbled and I cant edit.System Windows Vista home prem. thanks
Check the resolution of your scanner because this would effect what you see on your computer monitor. Maybe using a lower resolution would work for you or try scanning complex images as pictures. Good Luck
Fehdi
Apr 14, 2009 | Computers & Internet
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Hardware Internal Fault
This looks like a hardware fault. I hope (by now) that you have got an RMA and had it replaced.
Oct 13, 2007 | Visioneer 9450 Flatbed Scanner
Canon FAXPHONE L170 Plain Paper Laser Logo
old marine
old marine
