Question about Hitachi 53UDX10B 53" Rear Projection Television
Scrolling lines in the picture
I bought this Hitachi Ultravison 53 inch TV in 1998. It was working good all these days without any problem. Of late the scrolling lines appear when watching the television. If I shut down the TV for 10 minutes and turn it on afetr sometime, the scrolling lines don't appear
    President:
  • 3,130 Answers
The capacitors in the sweep supply and maybe in the main power supply are starting to dry up. Your going to need to get a tech to go over the boards and search out the dryed capacitors. It will take some time and maybe a bit costly. May want to think maybe about a new set? Good Luck
Posted on Aug 14, 2006
SOURCE:
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Dec 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi HD 53" digital projection tv
Good Day; brannie1;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
HitachI HD DIGITAL TV 53"
Good Day;
50UX18B Hitachi Projection TV
Good Day, monarchdr272;
Sounds like you may have a bad comb filter. Yes things can be repaired. Good Luck, big IRISH.
Aug 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
HITACHI 53" REAR PROJECTION
Good Day;
Some cable techs are good but too many are not.l So, if you have not solved this by now try this:
Unplug TV & box, wait 5 minutes plug both back in (reboot).
Good Luck.
May 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
116 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
