Question about Xerox WorkCentre 4118P All-In-One Laser Printer
HOW TO FIX SCANNER LOCKED ISSUES ON XEROX 4118
3 Suggested Answers
  • 2072 Answers
SOURCE: scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Posted on Dec 22, 2008
SOURCE: display says Scanner locked
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
Posted on May 17, 2010
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
Jan 10, 2011 | Xerox WorkCentre 4118 Network Kit...
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Drivers installation
Here is the web page with your Xerox printer drivers and software:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WC4118&Xlang=en_US&Xcntry=USA
Regards,
Graemevm
Apr 28, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox wc 4118 scan option
You will not be able to send the scan request if you are not inloco.
Jul 24, 2008 | Xerox WorkCentre 4118 Network Kit - 1 x...
Xerox WorkCentre  4118P All-In-One Laser Printer Logo
2,125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
