Question about HP LaserJet 5200tn Printer
Hp laserjet 5200tn service error code 49.4c02
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
  • 17 Answers
SOURCE: problem with our printer 5200tn
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
vendor for assistance.
Posted on Dec 18, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
Hplaserjet 5200 rfu error problem
1- we want to instal printer to local computer
2- the computer cant sport the the usb line of hp laser jet 5200
3- the printer menu is locked and we can't change it in the printer screen show the rfu error for upgrade
Jun 11, 2012 | HP LaserJet 5200tn Printer
50.8 fuser error
error code 50.8 what is the problem
Jun 05, 2012 | HP LaserJet 5200tn Printer
P4015n laserjet printer getting error 13.20.00
That Error code means a paper jam. If you can't find any paper, then could be a sensor. But thats unlikely. Its probably a tiny piece of paper stuck on the sensor.
Aug 19, 2010 | HP LaserJet 5200tn Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp laserjet 5200tn no display
Is it in sleep mode, or is this some other issue? Scroll down to the resets submenu in this article .
In fact, you might try simply resetting the printer, to try and clear the memory, but if you choose to do so, make sure you have printed a configuration page beforehand so you have all the info needed to set it up again.
Or you could try an online diagnostic session with HP, available here.
Finally, your model home support page with other troubleshooting options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | HP LaserJet 5200tn Printer
Need to find a service manual for an HP LaserJet 5200TN. Do you know where I can download the manual?
You can request a manual from this site just copy and paste into your address bar
http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hp_laserjet_5200tn_q7545aabe.html?ct=support
Dec 18, 2008 | HP LaserJet 5200tn Printer
Problem with our printer 5200tn ...error 49 4c02
49.XXXXX ERROR
alternates with
943 service print head error
sounds like a mirror motor error(this is the laser mirror that spins very fast 20k rpms, you hear the sound when its about to print ,sounds like a jet spinning up). In this case you will need a pro to look at it or replace the machine....
Aug 12, 2008 | HP LaserJet 5200tn Printer
HP Laserjet 5200
Hi, Here is a link to the service manual. It is in PDF so might take a couple minutes to open. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf Hope you find what you're looking for. Thanks, Lolita
Jun 02, 2007 | HP LaserJet 5200tn Printer
HP LaserJet 5200tn Printer Logo
1,421 people viewed this question
Seeker5211
Seeker5211
