Question about Boating
Key start doesn't work on evinrude
Not sure of the year but i'd guess an 86 model maybe. the way to start the boat is turn the key and pull the cord. it fires right up. It won't start thought when i turn the key. it doesn't make a sound. I guess my question is if theres a diagram to follow to wire this or how do i need to get this thing firing when i turn the key? not to good with electrical things also so explain in very good details please. anything would help.
  • Boating Master
  • 3,497 Answers
Hey Alex,
Does your kill switch still work?? IF NOT - GET THIS FIXED QUICK!! Get a multimeter,, set to volts.
You need to have power to the stater solenoid first..The solenoid is the "switch" that transfers power from the battery to the starter..the solenoid has heavy duty contacts that transfers low current to a high current for the starter.
. You need to determine if you have voltage to the solenoid..with the KEY ON.. check for voltage on the connection from the battery -it should be 12 + volts.... if YES, ...then CAREFULLY jump the major solenoid threaded studs with a screwdriver.(the one with the battery cable and the one that goes to the starter...((((SPARKS WILL FLY - and could cause a FIRE!!)))) IF the engine starts, you have a bad solenoid. If you do not have voltage going TO the solenoid.. you need to check the battery terminals, check the solenoid connectioins... and have your battery checked for COLD CRANKING AMPS... you can actually have 12 volts and NO amperage to "drive" the voltage..the symptoms would be exactly as you describe!!!
Posted on Jun 21, 2017
5 Suggested Answers
  • 583 Answers
SOURCE: Preventive Maintenance?
do yourself a favour and put a new impela in the water pump. as far as the key is concerned -----force is a part of mercury ,mariner--- if you go to either of these dealers they will have the right key for it at one time i had 1 key that fitted 2 of my4 out boards ihad at that time from youdoit
Posted on Aug 13, 2009
Testimonial: "thanks, did consider impeller, figured its probably rotted by now. I wanted to see if I can use my evinrude because its still hooked on the boat"
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
Posted on Nov 08, 2009
  • 46307 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
  • 44 Answers
SOURCE: 1997 50 hp Evinrude won't fire
Take off the top & expose the magneto clean with a fine grit sandpaper that should get fire to the plugs if still no fire u may have.to replace the points
Posted on Jul 23, 2012
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
Evinrudeomc 6hp what year
Evinrude OMC Model#E6REIA. Year please.
Alice, 1991. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1991 Evinrude E6REIA 6hp Outboard Motor Parts by Engine Section
1991 Evinrude Parts
Mar 24, 2016 | Boating
I need information on an evinrude outboard unsure of year or HP serial number is 4416-03315
Sounds like it could be an Evinrude Sportsman model 4416. Here's the info I found online:
  • Model: Sportsman - 4416
  • Make: Evinrude Motor Co.
  • Inboard/Outboard: Outboard
  • Engine Type: Gasoline
  • Production Date: 1947
  • Engine Design: Two-Stroke
  • Horsepower: 2.0
Check google search for pictures and more info on it!
4416 evinrude Google Search
Jun 16, 2015 | Boating
Motor Won't Idle
Sounds like dirt in carbs
Dec 14, 2013 | Boating
Evinrude outboard motor serial number c7108106
The Manual Store also has some useful boat motor model year lookup data:
Boat Motor Model Year Lookup Guide
Jun 30, 2013 | Boating
Hello, I have a bobcat mini excavator. Mitsubishi motor.. if I was to guess the year its maybe a 2001 or up.. it has a little over 1400 hours on it. Oil & filter was changed at 928 hours... While it...
It could be locked with oil in the cylinder. Remove the injector and turn the engine by hand to expel the oil. Top up the engine oil and refit the injector. If the engine won't turn with the injector/s out then it is seized and needs rebuilding.
Mar 11, 2017 | Cars & Trucks
I have a problem starting my 70hp evinrude outboard on cold starts. i have to use starting fluid to start
Check the fuel filters are not slightly blocked and also look that the electric choke is working properly,giving you full choke.Take the cowl off and when you press the key in to work the choke,make sure you can see that the solonoid is working correctly.Don't listen,look.Hope this helps you
Nov 25, 2009 | Boating
Boating Logo
57 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
