Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
SATA HDD make SLAVE
How can i make may another SATA Harddisk as a SLAVE?
i dont see any jumper settings in may Barracuda 7200 harddisk to change to become a slave.
  • Anonymous Nov 20, 2008
    i also have the same problem.i want to set it to slave but it says nothing about how to set the jumpers to slave.al it has is master and cable select.
    Problem Solver:
  • 11 Answers
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Posted on Nov 24, 2008
MODEL ST3400832A
You must check the harddisk(HDD) connectors and cables unplug and replug them and try to check again
Mar 22, 2013 | Seagate Barracuda 400GB 7200 RPM SATA 3.5...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My boot screen shows secondary slave hard disk error press F1 to resume. if i press f1 it enters into bios setup and the i press esc discard changes logging into windows but secondary disk is not detected....
Check on harddrive you find jumper on it.
Then read on harddisk you can find there is specifiaction for master, slave and cable select jumper settings.
Put jumper as cable select then check.
Also reconnect sata or ide and power cable to harddisk.
Then check .
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Computers & Internet
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
2,501 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
