Question about Western Digital Velociraptor 600Gb 35 Sata Inter SATA II Hard Drive
Velociraptor SATA2 Jumper - Western Digital Velociraptor 600Gb 35 Sata Inter SATA II Hard Drive
    Master:
  • 362 Answers
Hello, you don't say what you want to know, but read this info at the following link as it might help you:
http://www.techarp.com/showarticle.aspx?artno=590&pgno=4
Regards, nicam49
Posted on Feb 14, 2012
Putting this drive in a dell, I,m Not familiar With the Jumper settings,SSC,PM2, Opt 1, opt2, i,m use to CS, Slave,Master ETC
http://wdc.custhelp.com/app/answers/detail/a_id/1400#jumper
http://www.overclock.net/faqs/99291-info-what-ssc-jumper-my-hard.html
Jun 09, 2011 | Western Digital WD2500JS 250GB SATA2...
Gigabyte g31m-es2c motherboard can't detect my sata hdd
dude make sure if the jumper pin is set properly
as i think your MObo is sata 1 support and all new generation Hdd are sata2 support so u have to set the jumper pin. the setting are different fro different Hdd so check the producers website.
Mar 16, 2010 | Intel Motherboard
To raid, or not to raid,? that is the question............
Always a good question,
For #1
Always a good idea to mirror your OS drive for quick recovery. So yes I would use 40GB of the velociraptor for a mirror. However if your board supports it I would actually suggest you would be better served for your dollar to buy some 500GB+ WD greens or seagate 7200.12's(do NOT buy 7200.11) then set them up as raid5, frankly you'll get redundancy and speed, with more space. 4 Greens will perform as well as three VRs and cost less.
I currently run two Greens and 2 7200.12's on my home server and the 7 rating is 7.6 for my HDD and I've got 4.2TB of space for under $500.
I mentions some of the pro's and cons in detail on my blog last week Pro's and Cons.
Hope this helps,
Chris
Mar 07, 2010 | Computers & Internet
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
HARD DRIVE INCOMPATABILITY ISSUES
I evidently figured this problem out on my own. Because I pulled these two drives apart and they were part of a two disc array, the 3Ware Raid controller assigned one as "master" and one as "slave". So, even though they will appear as perfectly good hard drives to ANY pc and you can load an O S on them, they will read as either a slave or master upon hard boot-up. There are two ways around this. One--you can leave them in your pc and "delete" the array in the BIOS and then re-format them, or Two--before or after you reload your O S, power down and unplug your pc. Then pull the COSMOS battery out and reset the "clear cosmos pins" on the motherboard. Leave the battery out for 3 to 5 minutes and then re-install the battery and re-set the "jumper pins" back to their original position. Ofcourse, if you had any overclocking settings previously set in the BIOS, you will have to set the parameters of your choice once you re-boot. It actually takes longer to write this explanation than to do the deed. Problem solved.
Feb 27, 2009 | Western Digital Raptor X WD1500AHFD 150...
Maxtor hard drive model 54098h8 where do I put jumper for main drive
on the model 54098h8 this is a IDE drive and was in service in the mid 2000 era. most drives warranty expired by 2003.
the jumper postion is for J50 which is MASTER with jumper ON and SLAVE OFF See photo below or look on this link
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/d540x-4k_guide.pdf
All material contained herein Copyright © 1999 Maxtor Corporation.Contents and specifications subject to change ®
without notice.DiamondMax™, MaxBlast™ Plus and MaxFax™ are trademarks of Maxtor
this is a photo of the master from the PDF
May 07, 2008 | Maxtor Hard Drive
Bios settings
at bios settings choose auto detect for secondary master and secondary slave.
one burner must be master and the other one is slave jumper settings. all burners must be place at secondary drives.
Jan 24, 2008 | Adaptec (ASH-1233) (ASH1233) ATA...
Western Digital Velociraptor 600Gb 35 Sata Inter SATA II Hard Drive Logo
185 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
