Question about Garden
S2046 scotts mower wiring diagram - Garden
5 Suggested Answers
  • 248 Answers
SOURCE: the mower deck belt on my scotts s2046 comes off
you should have some type of belt tensioner,most common type is a pulley with a spring to hold pressure on belt.Spring may be missing or stretched {2}belt could be stretched {3}pulleys may be out of alignment
Posted on Oct 06, 2010
mowerman1857
  • 389 Answers
SOURCE: I need a diagram on how to install a ground drive
Go to this link, it shows a real clear image of how the belt is supposed to go:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet
Posted on Sep 19, 2009
Tech_Mate
  • 680 Answers
SOURCE: I have a scotts/john deere
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
Posted on Jan 10, 2011
SOURCE: _i need a belt diagram
Hi lockamy_jeff,
I searched a Diagram as requested regarding your Scotts S2046 Riding Mower.
Manual/Diagram
See the link above for the Diagram this is also a Manual for the Machine your Bekt Diagram should be under Service Mower then Mower Drive Belt Replacing, this should direct you exaclty to the Belt Diagram.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Posted on Jul 02, 2011
How do i replace the bladeees belt?
Remove the deck, Find the pattern of the belt direction on each pulley. While deck is removed check for sharpening blades and greasing spindles.
Apr 08, 2015 | Briggs & Stratton Starter Scott's Equip...
Scott's 2046 ignition switch broken. How do I remove and replace?
There should be a rubber slotted cover that key goes through. This should pop off with a screw driver to expose hex nut. Unscrew hex nut and replace switch.
Oct 18, 2013 | Briggs & Stratton Starter Scott's Equip...
Engine idoling way to high
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
Oct 24, 2012 | Briggs & Stratton Starter Scott's Equip...
The plastic starter gear keeps breaking on my 24 hp. I have inspected the flywheel gear and it is in good condition. I get one or two starts and then the gear breaks. This last time I thought it was going...
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
May 13, 2011 | Briggs & Stratton Starter Scott's Equip...
I have a scotts/john deere s2046 riding mower (man date 12/98) --hydrostatic trans making a groaning noise--want to fix it before it fails--is there a rebuild kit of some kind?
Terry
Jan 09, 2011 | Briggs & Stratton Starter Scott's Equip...
The mower deck belt on my scotts s2046 comes off after a minute or so of operation. What's going on? Thanks
Oct 05, 2010 | Briggs & Stratton Starter Scott's Equip...
I have a Scott s2046, when I pull the choke to start it
did you recently change the fuel filter? When I changed the fuel filter that used to happen to me. What worked for me was loosening the gas cap and it would continue to run, over time the fuel filter soaked in the fuel more and the mower ran fine, give it a shot. Good luck
Mar 10, 2009 | Garden
Garden Logo
690 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
