Question about Frigidaire Kitchen Ranges
OVEN MODEL#FGF316DSE Oven won't light
SOURCE: How do you light the oven pilot light? The model
We are replacing the range . . . too old and no parts are available.
Posted on Dec 29, 2009
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
jumptrout51
  • 3361 Answers
SOURCE: where are the fuses on
This factory service manual will help you.
First,verify 220 volts to the range at the terminal block on the rear where the cord connects.
http://servicematters.com/maytag_library/docs/16025644.pdf
Posted on Oct 03, 2010
allbrands
  • 600 Answers
SOURCE: I have a Maytag gas
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
oldTech2332
  • 2341 Answers
SOURCE: The oven won't turn on. I smell gas but no
hello,
there is no pilot light,it uses a glow bar style electric ignotor which is weak, it is just getting hot enough to somewhat open the gas valve partitally but not hot enough to fully open valve or ignite the gas,UNDER NO CIRCUMSTANCES should you attempt to turn it before replacing the oven ignitor since gas could seep and fill the oven chamber then finally ignite and blow the door out extremely forcefully(with it turned off presents no such danger at all) according to the website i use to look up part numbers the replacement part# is 73001165 you could order it at searspartsdirect.com or look in your phone book and find a appliance parts dist. in your area,or of course call a service company in your area, if i were doing this service call (im in the wash. dc area) the charge would be appx.$450.00
Posted on Jul 22, 2011
Electic range oven won't maintain temperature
What is the complete model number of your unit?
Feb 18, 2013 | Kitchen Ranges
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Whirlpool oven won't light
check the bulb in the oven
or oven light wsitch look more to the bulb
Aug 01, 2012 | Whirlpool Kitchen Ranges
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Dont know how to set the clock on my cannon gas cooker
Before anyone can answer this we'd need to know the type, model number and manufacturer of the oven. Sorry.
However, it's odd that the oven won't work if the clock won't. Usually it's the other way around.
Oct 24, 2011 | Kitchen Ranges
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Kitchen Ranges Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
