Question about Datalogic Magellan 8400 Barcode Scanner
I have Error Number 2 and 6 how i can fix it - Datalogic Magellan 8400 Barcode Scanner
How to fix a problem when the machine report e000001 error?
follow these steps: (with machine powered on)
1. press adittional function
2. press number 2
3. press number 8
4. press adittional function again
5. with the left arrow search for "clear" and click ok
6. with the left arrow search "engine" and click ok
7. select " ERRCLR and press ok
8. turn the machine off for about 5 seconds from the main switch.
9. power on the machine and try to make some copies.
10. if problem persist replace the fixing heater assembly
May 02, 2014 | Canon Office Equipment & Supplies
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
Density shutter error
The density sensors are dirty (probably toner on them). This is usually caused by the cleaning blades being worn out on Item #31 on Printer Unit page 2/2 part number 42755401 needs replaced.
Printer Parts Diagram and part numbers
Jul 05, 2013 | Oki Printing Solutions C9650 Led Printer
Model# 11087721700, with f01 error fix
The error code f01 indicates the primary control board failure. Before you replace that board I suggest that you unplug the dryer for 2 minutes then see if the error come back. If it does replace the board part number W10110641.
May 13, 2012 | Kenmore HE5 Electric Dryer
CODE F51_2
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Jan 04, 2012 | Konica Minolta Office Equipment & Supplies
0xc00000a5
schedoro, The error 0xc00000a5 Can be fixed easily.
What is 0xc000000a5 error? This error is the Hexadecimal format of the error caused. This code is used by the vendor to identify the error caused. This error code has a numeric error number and a technical description. In some cases the error may have more paremeters in 0xc00000a5 format.
How to easily fix 0xc000000a5 error. there are 2 ways to fix this error. 1) Start your computer and log on as administrator. 2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore. 3)In the window, select "Restore my computer to an earlier time" option and then click Next. 4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next. 5) Click Next on the confirmation window. 6) Restart the computer when the restoration is finished.
I hope this works for you. You can read all of that or used this:http://www.wiki-errors.com/wiki-errors.php?wiki=0xc00000a5 Thanks wiki, Wiki can help alot of people :)
- Steven ASAP
Here to help!
Apr 24, 2011 | Google Chrome
Machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Dec 30, 2008 | Brother MFC-8860DN Printer
Hp 3005n error on display
What is the error number that comes up there should be a code that is displayed. Once I have this number I will be able to tell you why you are getting the error and how to fix it.
Thanks J
Jan 21, 2008 | HP LaserJet P3005n Printer
Servise mode
different models use different display methods, if there is any sort of touch screen it will appear there in an alpha-numeric display
eg U4-2 or J3-2 etc.others just display symbols if there is no touch screen (symbols like a pyramid of dots for out of toner, crossed circle for drum end of life etc) some of those will display a number if you hold down the clear button or the stop button, depending on the model
there are probably 5 or 6 different diagnostic systems needing different entry modes...you will have to be very specific with both the code and the model number of the machine
Nov 29, 2007 | Office Equipment & Supplies
!SisRegistryServer error
We have 2 problems :
1-Application
!SisRegistryServer
Reason Code
ucmp
Reason number
0
2-Application
Application installer
Reason Code
KERN-EXEC
Reason number
Nov 13, 2007 | Sony Ericsson P990i Cellular Phone
Datalogic Magellan 8400 Barcode Scanner Logo
26 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
David Payne
David Payne
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
