Question about Universal Remote Control MX-850 LCD Remote Control
My RX850 was Dropped and does not come on.
Remote was dropped and does not come on. When i took it apart there was a square pad with a wire spring that was loose and rattling around. where does it go and how do i put it back together?
    Problem Solver:
  • 6 Answers
Trace where u thingk it suppose to be and resold
Posted on Feb 14, 2012
  • Mike Angle Feb 14, 2012
    SO IT DOES GET SOLDERED? MY EYES AREN'T WHAT THEY USED TO ME SO I WASN'T SURE. I CAN SEE WHERE IT LINES UP. THANKS
I dropped my x-10 palm pad remote in water
I've dropped a lot of phones and other devices in water! No feeling quite like it :(
Maybe people will advice against this, but I take the hose to my vacuum and (with the batter out) vacuum every inch of my devices. Another tip that has worked is to put the device into ziploc bag of white rice for a day or so. It'll absorb any water that is still locked inside.
Hope it works for you!
Jul 05, 2012 | X-10 X10 Palm-Pad Remote Control
I have a Bose remote that I dropped several times and I want to know if that could be fixed. It is RC28T1
Yes it can be fixed if you have patience and know your way around soldering.
FIrst its tough to take apart. I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
Oct 26, 2010 | Bose Lifestyle 28 System
Blank Blue Screen, but buttons still work
I had the same problem and when I took the remote apart the ribbon connecting the lcd screen to the remote controller board was sheared. The remote was dropped and the impact caused two of the traces on the ribbon to tear.
Sep 29, 2009 | Logitech Harmony 890 LCD Remote Control
When I push the power on it opens and makes two rounds of beeps and instantly shuts down and the lens retracts.
I had the same problem. I took the lens assembly out and took it apart and found a broken plastic tab that connects a very small spring for the focus lens. Apparently the lens tries to autofocus, but can't because the spring is not connected so it then shuts down. The spring is near the smallest motor in the lens assembly. I made a new connector for the one end of the spring out of a small wire and glued it in, then put everything back and it fixed it. This is like working on a watch, everything is very small, I mean tiny. You need much patience and a steady hand for this job.
Aug 14, 2009 | Casio Exilim EX-S600 Digital Camera
Replace front brake pad 2003 toyota 4 runner
Diagram is unnecessry.
Pull both front wheels
Work one at a time leaving the other for reference
Find the retention spring ... its a paperclip thickness wire spring... dislodge center retention loop and undo from both ends which engage brake pad retention rods.
Pull the rods out
Pull the old pads out... laying everything on the ground
Use scrap wooden wedges to pry between the rotor and the caliper ...inside and out until the calipers are fully withdrawn. Use the new pads to measure if they are far enough back.
Note... the brake fluid will have dropped in the master cylinder over many months of wear... do not fill it. When the calipers are pushed back they will fill the reservoir again... one wheel at a time.
Be sure to identify the correct pad based on what you took out and what is on the other side (if you screwed up the layout)
Make sure to take the old antisqueek backing plate from the old pad and place it on the new pad. They don't use lubricant on these anymore.
Replace the pads... the retention rods... then the retention spring
Do the other side
Then progressively step on the brake peddle until full tension is felt
Check the master cylinder reservoir... probably needs no additional fluid.
New pads will register in existing ridges in each disc in no time at all.
You should check the discs to see if they need to be replaced during this operation...using some calipers
Mar 19, 2009 | 2003 Toyota 4Runner
Screen out
I have one that the screen is out, I dropped just like you guys and when i took it apart I noticed that the ribbon cable that is going up to the screen, some of them had torn and that is what caused my screen to go out. You might want to check that out.
Sep 16, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Dropped DS Lite - rattling
L2 inductor comes out sometimes when dropped and the DS keeps in fixed amber light when charger is plugged in. But you found it fast so good luck. Its pretty sure your DS will work again after soldering the L2 again in its place near the power switch. Just get the battery and charger out before doing anything to avoid a blown fuse also.
Sep 05, 2008 | Nintendo DS Lite Console
Universal Remote Control MX-850 LCD Remote Control Logo
214 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
