Question about Mitsubishi WT-46809 46" Rear Projection Television
Wt-46809 first off i have to say i d o ot under stand vey well how this is supposed to work.This the third and final time i am going to try to get help here( i have got alot of help but just when i think i am there i guess i hit the worng button). I have already replaced the ics and the pico fuses and the vertical ic and i am still gettig 2-3 error code please help.If i have made anyone upset before i didnt mean to not ask for more help i didnt know if i hit for more help that it would go against you. Thanks, Chris
  • 4 more comments
  • chris leck Oct 25, 2008
    Im sorry it is a mistubishi wt-46809 and i get a 2-3 error code meaning horizontal defelection failure.
    Thanks
    I have done what you have asked and i never took the flyback off but should i check them them anyways ?
    thanks
    It also does not seem i am gettign power from the fly back.
    thanks
  • chris leck Oct 26, 2008
    Its all stated above.
    thnaks
  • chris leck Oct 27, 2008
    I am not sure what i am doinq worng but when someone replies to my problem and asks a question i repond with a comment but i never hear back from them.
    I already have a copy of the service manual.thanks,
  • 320 Answers
Ready2helpu, did you happen to check that second link before you posted it? This one:
http://pvbrick.com/htmlfiles/bottom/3/pages.php?id=1011
It goes to a page that gives absolutely NO information to help the user. Next time, rather than just cutting and pasting the links from Google search, you might want to check and see if they are any good.
Posted on Oct 27, 2008
  • Mitsubishi Master
  • 19,396 Answers
Check for cold joints on the flyback trasformer, there is also a service setup procedure to adjust aligmnet that you must perform after replacing the STK.
    President:
  • 1,952 Answers
The failure is in the vertical deflection amplifier; a common cause and a good tech should be able to get it going again very easily.
Posted on Oct 25, 2008
  • mohammed marika thambi
    mohammed marika thambi Oct 26, 2008
    check whether voltage were correctly passing into video card ?
  • 83 Answers
Download service manual for your tv from below link:
http://www.nodevice.com/manual/newmans/V18_Service_Manualpdf/get15995.html
    Sergeant:
  • 208 Answers
Can you tell what is the kind of problem you are experiencing ? and can you tell the error codes you are getting?
Thanx...
  • 905 Answers
When you said it was working but the convergence was off so you checked your work , well that means when you moved the board one or more solder joints have cracked or the pin in the solder is not connecting , also you are supposed to adjust the conversion settings in the service menu.
so resolder everything and check all the resistors values on the stk
let me know what you get (also resolder flyback pins real good)
  • 3 more comments
  • jason Oct 26, 2008
    then you will need to check to see if the voltage is going to the flyback , but first check the horizontal ocilating circut in the power section see if there is a problem with that
    I'll be back to check your progress
    electech
    also you will not get power from the flyback if the tv don't start up
    you should make sure all solder is good and sometimes have to resolder just to make sure it will not come undone
    have you checked the horizontal oscilating circut , and resoldered ?
    also do a voltage check in the stby( stand by) circut , make sure the voltage is there
    let me know what you have got from these tests
  • jason Oct 28, 2008
    i thiink refreshing the page will show you a new solution
    and i am here to help regardless of any money involved
    I am here to help , i am not here for the money
    so if you still want help you can also ask me directly
    have you resoldered and checked the resistor values on the STK's?
    Scholar:
  • 136 Answers
Give the proper model number and company of your unit and .
tell what error codes u receive after changing those ICs.
to help you further.
thanks.
  • 1 more comment
  • ready2helpu Oct 25, 2008
    More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
    One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
    If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
    Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
    http://pvbrick.com/htmlfiles/bottom/3/pa...
    also check out the above link
    thanks.
    feel free for further queries.
    keep us all updated to help you further.
Troublshoot Mitsubishi wt 46809
Fuse will not be bad if green power light comes on and stays on--if it came on and went off there is a self check.
Likely issues: if no sound also-----problem is in either power supply or set is in shutdown---has a latch circuit.
I have another suggestion based on having worked on hundreds of these sets-----Look first directly under the picture tubes and above the main boards---is there a gray or black plastic tray running under them?
Let me know what you have tried etc by pressing the "make a comment button" here-----
Mar 26, 2012 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809
can you please explain your problem.
Oct 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Not enough hd inputs for mitsubishi wt-46809
The splitter may work or an audio/video switch box like this one
http://www.buy.com/prod/belkin-hdmi-3-to-1-video-switch/q/loc/101/204114788.html
May 03, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
No sound
have you tried dvd or other sources?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809 Not coming on
Try hard reset==leave unplugged from AC a while.
Next--NMI==need more information!
Is this your first problem? Any symptoms before shutdown?
Oct 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
