Question about Compaq FP 7317 17" LCD Monitor
Green light and screen flash then go blank every 3-5 seconds and nothing else
When I power up it turns the green light on until the monitor flashes, then it all goes dead. Then every 3-5 seconds it tries again and the green light and the monitor flash then die again, it is a constant cycle (over and over). This is my first flat panel and I bought it used (guess I should have got new lol)any ideas? Thanx, Will
  • 2 more comments
  • Anonymous Oct 08, 2008
    My FP 7317 has worked for 2 solid years, and one morning upon start up, the monitor screen flashed on, and then immeditaly shut off (green light goes off as well). After roughly 1 second of darkness, the green light on the monitor turns on, the screen flashes on for half a second, and then it turns off again. This constantly repeats.
    I have unplugged and replugged the cord feeding into the tower as well as the main power supply. I have turned the tower off, unplugged the cord leading to the tower so the monitor is just connected to the main power supply and it still flashes.
    Is there a piece broken inside of the monitor? Or did it just kick the can after it two year long life?
  • nasservhussa Jan 02, 2009
    My HP L1702 works without any problem for around 20 to 30 minutes. After that it will start to blink every 2-5 seconds. In between, I can see whatever was displayed on the monitor previously. It will start to work normal again after 10 to 20 minutes. If switched off for 10 minutes, it will work normal for another 20 minutes or so. Can anyone offer a solution for this? I am a little tech savvy and I may be able to dismantle it and solder a wire or two if necessary.
  • Anonymous Jan 27, 2009
    I have the same problem. Did you find a solution?
  • lionimage Jan 27, 2009
I know im way too late for this, but your power supply is bad or wrong. must be 110 ac input-12 volt 5 amp dc output. just got a used one with no cord, found out the hard way. of course. had a 12v dc output but it was only 564ma. about 1/2 amp which did exactly the same thing
Posted on Sep 04, 2008
Heat from the switch mode power supply in the unit will detierorate the 1000mfd/16volt caps.I replaced all 4 of mine to restore from a dead unit
Posted on Sep 21, 2007
Turn of the monitor and computer and trun them on at the same time but before you turn them on hold down F8 if that doesn't work sorry, i tried
Posted on Nov 15, 2007
    Problem Solver:
  • 3 Answers
Not sure I can tell you the exact nature of the problem with the info you have given. However, here are some trouble shooting tips. These are the things I would do to figure out what is causing the problem: 1. Hook up a monitor that works so that you can make some configuration changes to the graphics card. 2. Find out the native resolution of the LCD monitor that has the problem. Many 17 inch and 19 inch LCD's are 1280 X 1024 with a refresh rate of 60 Hertz. It is quite possible that your previous monitor settings are not compatable with your new LCD monitor. This is an easy fix. So go into your graphics control pannel and start by making sure that your refresh rate is set to 60 and the resolution to 1280 x 1024 or perhaps even lower like 800 x 600 but 1280 x 1024 is fairly standard with many LCD's. 3. With these new settings hook your LCD monitor up again and see if that works. 4. Still not working? ... Then there may be a problem with one of the hardware components in the monitor. When the monitor flashes are you for an instance seeing an actual picture? If so then the problem may be with your lamp controler. It's what controls the brightness etc. of your monitor. What you can try to do is lower the brightness. This sometimes restores the monitor to being useful. ie. you can use the monitor but only at a lower brightness. Setting the monitor to a lower brightenss may be a bit of problem if you can't see the brightness control which is often displayed on the screen itself through the menu function. If you are briefly seeing a picture as it goes through this 3-5 second cycle then hit the hardware menu button on your monitor. You should then see some sort of menu that you can control with the other buttons on your monitor. Find the brightness selection and lower it. You can lower it all the way to 0 and still have plenty of brightness to see a picture. NOte: you may have to make the change in brightness within one cycle of it going off and and on because each time it cycles it's quite possilbe that it resets itself. So in this case you would have to be really quick with the menu buttons on the monitor. It might take a couple of tries (or more) to get the squences of buttons you need to hit to get the brightness down. I had this problem once with a monitor and I was able to get the brightness down but only after many tries. I had to be supper fast with my menu selections. After that was done it worked flawlessly again. 5. Still not working? ... you are right you probably should have bought a new one LOL ... or next time when buying a used one make sure that you see it functioning correctly on a computer before buying it etc... Best of luck. Sincerely, Dean Dean Kenneth Robinson techinfo@ContinuousMix.com
Posted on Aug 16, 2006
4 Suggested Answers
silly girl
  • 513 Answers
SOURCE: compaq tft 5005
Did the same and burnt a frazzled chip. it is on the 3rd circuit board (I believe it provides the lamp power). It is the 8 pin surface mount chip next to C900. As far as I can make out, the numbers on the chip are 4559 **** **7B I was told it's the lamp drive. If it is indeed lamp drive, then when you turn the monitor on, round the edges of a flashlight pressed to the screen, you should see a picture. If there isn't one, you may have killed more than I did. Is there no power regulator at the input? Good luck
Posted on May 23, 2006
SOURCE: Fp 7317
My monitors green light stays on, but the screen will come on for a second then goes off
comaq fp737
any ideals
Posted on Oct 05, 2008
frcs68
  • 1605 Answers
SOURCE: Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Posted on Oct 22, 2008
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
I have a Star Logic LCD monitor. Recently I have been having a problem powering the monitor on. Sometimes when I press the power button or bring it out of hibernation, the screen remains black and the...
First place to check will be the DC filter caps in the power supply section. See example of failed monitors due to bad caps here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 10, 2010 | Star Logic 17" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
How do I turn off the change oil light on a 1994 corvette
1. Turn the key to “Run,” but don’t start
2. Press “ENG MET” on the Trip
the engine.
Monitor. Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The
“CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the
“CHANGE OIL” light stops flashing
and goes out. This should take about
ten seconds.
When the light goes out, the monitoirs
reset. If the monitor doesn’tr eset, turn the
ignition off, then try again.
Nov 18, 2008 | 1994 Chevrolet Corvette
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Compaq FP 7317 17" LCD Monitor Logo
1,440 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
