Question about Air Tools & Compressors
I have been given a Jetstream JETTD-2021 2HP 21L Compressor and there's no user manual. It was loaded in a car and some oil came out of the motor. There's no user manual and i'm trying to
Oil Level in a JETTD-2021 21L 240V motor Compressor.
    Genius:
  • 1,212 Answers
Normally it should be level with the top of the hole that leads into the main casting when viewed from a fill plug that is horizontal/parallel to the floor located near the bottom of the compressor body- much like a lawn mower engine oil level.
On those where the filler is located in the side of the main casting, the level should be even to the bottom edge of the fill hole.
Posted on Feb 15, 2012
Testimonial: "Thanks John, I appreciate your input.The plastic filler cap has a small plastic protrution past the screw thread. It doesn't look like an actual dipstick and I'm told this is the genuine screw cap for the motor oil filler hole. Would to the bottom of the protrusion be a safe bet for the oil level do you think? My concern is overfilling it with oil and blowing out a seal or siezing the motor. Thank you again, I appreciate your time and advice, Cam"
3 Suggested Answers
  • 214 Answers
SOURCE: what is the required oil
Fill to the threads on the fill plug hole.
Posted on Jul 20, 2011
ollie reece
  • 1167 Answers
SOURCE: i have 2hp 25 litre marksman electric compressor
either by the sight glass half full or by the dipstick touching the line on the dipstick (fillerplug) get back to me if need more info
Posted on Sep 30, 2009
Black smoke, use too much petrol 21L/100km
2000 model v6 3 l will be efi not carby
check fuel pressure
check for leaking injector seals and faulty injectors
Jun 17, 2017 | Cars & Trucks
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
Why must I turn drum clockwise before it will go to high spin
check the motor coupling,if it's worn in the center it can catch and work and then slip or you have a bad transmission.when you check the coupling and if it isn't broke check for oil on the bottom of the transmission,if you find oil that's a good sign the transmission is blown.watch this video
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5501893181&kw=whirlpool%20coupler
Apr 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to add oil but don't know know what kind. I don't have a user manual George t
Most oil producers publish helpful application catalogues for their products. Some companies even dispense with technical specification and label simply "Compressor Oil" which removes much guesswork.
In the case of difficulty most larger towns will have a small company supplying all manner of hoses, pipes, seals, connectors and general trade and industrial requisites and often carrying out hydraulic repairs. Specialised lubricants are routine business for such companies.
Aug 19, 2011 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
What type of oil do I use in model CPLDC 2541S
If you mean the CPLDC2541S (Porter Cable air compressor), you need to fill it with an air compressor oil. The recommended weight is SAE-30 (API GC/CD heavy duty motor oil). You can use a SAE-10 oil in harsh winter condiions. The manual is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/20237/PORTER-CABLE-Air-compressor-L0309172 .
I hope this helps.
(note standard motor oils designed for cars are not appropriate for a compressor.)
Jun 21, 2011 | Porter Cable Garden
Ingersolrand air compressor gets hot and turns off. why?
You did provided manufacturer but not model, therefore advice given can be only very limited.
Ingersol i sproducing oilless as well as oil lubricated compressors, what is your type?
I assume that this one is piston, using oil.
1. Check oil level and condition, replace if needed/fill to correct level (too much is actually as bad as not enough in that case!).
2. Check inlet filter and throat if not obstructed, if encased, check if sufficient airflow through vents
3. Check and drain water from the tank, it is possible to waterlog lines if too much water condense in the tank.
4. Check air regulator settings and establish what is correct maximum for that particular machine
5. Output pressure too high, compressor runnig too high, lower output pressure
6. Output volume too high, too many tools/users on the line, reduce number of users/tools on line at same time
As motor is running without problem, you did not mentioned any, therefore driver, driver belts can be safely excluded from the equation.
From experience - seem like you need larger compressor...
Hope you find this advice useful :-)
Aug 08, 2010 | Garden
What weight oil do I use. New compressor not used
30 weight non detergent. Sears has this oil on the shelf or you can get the same at any auto parts place.
Non detergent is the key.
Refer to your owners manual for further information
Thank you for your service.
Oct 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
119 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
