Question about Volfenhag ZX-8200 Car Audio Amplifier
The one terminal on my volfenhag 1000wat amp does not work what could be the problem
Its a 2ch amp with a bass booster i hooked everything up right i dubble checked it and it still didnt work i switched the rcas around and nothing i only had one sub hitting i un hooked the sub that wasnt working pluged it in to the other terminal and it worked so i no its not my subs it has to be somthing with the rcas or the terminal what could the problem be
  • 341 Answers
It sounds like your amp has lost a channel, based on the testing you have done so far.
Posted on Feb 16, 2012
Does the remote bass control have to be hooked up on a volfenhag zx-8100 for it to work
No, it's only use to control the gain or level from zero to what u set it to
May 28, 2015 | Volfenhag ZX-8100 Car Audio Amplifier
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
No bass
could be the speaker its hooked up to . try to disconnect the sub and see if the protect light goes out
Feb 06, 2010 | Competition INTERFIRE BIG BOY 2CH...
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Volfenhag zx-8400 amp and ZX-4712DVX subs
First of what you have should work great together....now the next thing is: does the bose system carry powered speakers if so the spliced speaker wires should be put onto a converter(a small box with RCA outputs) then you should make sure the levels in the little box is not set to full but 75%, if set to full you can be looking at distortion. Then they should set the amps to full range and see what you get.........oh and by the way you don't have to use that little controller(with the telephone wire) for the bass. You can control the bass with the frequency controllers on the amp or your head unit. And it's not a german thing trust me they come with nearly all amps now. These guys are full of ****. If you don't get the punch you want they should try bridging the amp for more of a punchy sound. Oh and you can use that decent sized box with the vent holes......that should work fine.
Jun 15, 2008 | Volfenhag Car Audio & Video
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Connector
ebay..? dont know if they have.
Jan 17, 2008 | Lightning Audio S2.300 2CH 340W Amplifier...
Volfenhag ZX-8200 Car Audio Amplifier Logo
85 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Electro Med Services...
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
