Question about Timex 1440 53591 Sports Quotient Wristwatch
Turn off chimes timex 1440 sports - Timex 1440 53591 Sports Quotient Wristwatch
SOURCE: i don't know how to set my timex 1440 sports watch
1. it is easy all you have to do is hit mode
2.then you will se all zeros
3.hit mode again
4.then you will see a number blinking then press start/stop button and it will change to the next number
5.then just set it to your clock time and your done!!!!!!
hope this will help you
Posted on Dec 29, 2008
SOURCE: Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Posted on Sep 27, 2009
SOURCE: Alarm
On this 1440 watch to cancel the alarm first push the adjust button (bottom right on this watch) this will bring up the alarm time previously set and while still holding the adjust button tap the stop/start button (top right on mine) this should deactivate the alarm
Posted on Sep 30, 2009
SOURCE: need instruction manual for Timex 1440 sports
I have this watch, it think its the same one, the manual on the website didnt work for me either :D
okay
To change the Alarm
Hold mode whilst on the time section.
then start/stop changes between hour and minute, adjust changes the number.
To get off that press mode again.
To change the actual Time
Go on to the stopwatch section Hold Mode, if it shows you the alarm press mode to change to time. The seconds should be flashing, press start/stop to change between hour minute second date, and adjust changed the number.
I really hope that helped even if its a month late :D
Posted on Oct 14, 2009
Testimonial: "I've had several Timex watches and this one is impossible! Thanks for the help."
Nomodo4u
  • 863 Answers
SOURCE: How do i set the time on a timex 1440 sports
Here you go old chap:
http://assets.timex.com/manuals/
Cheers.
Posted on Nov 13, 2009
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
How do I turn off chime?
Hello Mfchester,
Here are the instructions to turn off the chime on your Timex Sports 1440 watch. Please let me know if I can be of further assistance! :)
--Sandy
ALARM AND HOURLY CHIME INSTRUCTIONS:
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off.
  6. Press START/STOP again to turn alarm on /off.
  7. Release START/STOP when done.
Note: Please remember to rate this post if you found it useful.
Apr 19, 2011 | Timex 1440 Nylon watch
How do I turn off the hourly chime on the Timex 1440?
Use the mode button to toggle to the alarm function. Once at the alarm function, press start/stop. It wil turn the alarm on or off as well as the hourly chime.
Nov 10, 2010 | Timex 1440 Nylon watch
I have A Timex 1440 Sports Watch.How do I turn off the hourly chime?
browse through my tips and you will find link for all Timex watch manual downloads.
Sep 26, 2010 | Watches
Mid Size Sports 1440 Black Nylon Strap Watch: hi i forgot how to set the time on my timex 1440 s...
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
May 18, 2010 | Timex 1440 Nylon watch
Purchase watchbands for the timex 1440 sport
My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
Apr 25, 2010 | Timex 1440 Nylon watch
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
Aug 30, 2009 | Timex 1440 Nylon watch
The manual on Timex's site isn't for the 1440 Sport, so I kept looking through the forum. I finally found a solution that worked: hold the Adjust button (bottom right) and press the Start/Stop button (upper right). That should turn the alarm off (or on if you'd like). Hope that helps!
Mar 05, 2009 | Timex 1440 Nylon watch
Timex 1440 53591 Sports Quotient Wristwatch Logo
21 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
