Question about Pioneer SD-P50A5-K 50" Rear Projection Television
TV pops and shuts down
TV will work ok for days and then while I'm watching it will make a "pop" noise and shut down. In the past it would blow fuse 106 (4amp) and would not power back up until I replaced it. I upped the fuse to 6amp and I no longer blow the fuse (not the smartest I know). If I power the set off for a while it will normally start back up. There is a red flashing led on the board near fuse 106 when the set has powered itself off. There was an arc from the red wire at the base of the flyback transformer, I taped the wire and the arc stopped. I was given the set and I am wondering if anyone may know what the problem might be and what it would cost to fix?
  • ANIMAL51 Mar 13, 2008
    Tv is about 7 yrs. old and no trouble at all. I was watching the news the other night, there was a pop, and the tv went off. I tried to hit the power button, the green light came on for 1 sec., a little pop, and off again. I tried unplugging and waiting, but no good. What do you think?
    ANIMAL
  • bad_the_ba Apr 23, 2008
    I have the same or similar issue. It does not come on at all, just tries, pops, then shuts off usually within 1-2 seconds. The flyback transformer is available on Pioneer's parts website for 57.15 retail. I think I will give it a shot. The TV was recently given to me and has not worked since long before I got it. $60 + shipping is very little to spend if it works.
    President:
  • 3,130 Answers
Get a good fire insurance policy!! The problem you have is the flyback transformer but its going to be hard to get just that so order the sweep board that the transformer sits on. Also your making a very dangerous situation for you or your family. Im praying something doesnt go bad in the middle of the night and start the set on fire. As theres always power to that set. Good luck and dont risk your life or anyone elses to save a few bucks. Get a trained tech to service this set, as a TV set is no place for an experimenter to be. Good Luck
Posted on Aug 14, 2006
Car shut down while driving....
Did you blow a fuse or a fuseable link ?
Jun 18, 2013 | 1994 Ford Thunderbird
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
My whirlpool dryer was working fine then I heard a pop noise then dryer shut off
it sounds to me like a wire came loose and shorted out or popped fuse!!! Check your breaker box and if the breaker is not blowed or flipped, then you probably need to replace the dryer fuse!!!
Jul 16, 2011 | Whirlpool LER5636P Electric Dryer
Tv made a popping noise then shut off. wont turn back on
could just be fuse. check fuse near where cord attaches to power board. replace with same type fuse. if fuse is ok, possible power board or main board failure.
Jul 30, 2009 | Hitachi Televison & Video
Popping sound then no power
Hi! I think something to do with power supply.Try using different power outlet or have to replace the fuse inside the unit.If your tv is withing the warrenty dont open it,call samsung
Dec 12, 2007 | Samsung HP-R4262 42 in. Plasma Television
Will not turn on
We turned the tv off to go outside. Then when we came back in, our tv doen't want to come on. Green light comes on and then it goes back too red. It keeps doing that until u unplug it
Nov 28, 2007 | iLO 3200 32 in. LCD Television
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
80 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
