Question about Dell Latitude D430 Notebook
Boot from usb d430
I need to install Windows 7. Will a d430 boot from a usb flash drive?
3 Suggested Answers
  • 71 Answers
SOURCE: i installed windows 7 to my dell latitude d430
you need to see if there are drivers for your cdr drive for windows 7 you have to know what cd drive you have befor you install win 7.
Posted on Feb 01, 2010
SOURCE: my dell laptop model is
1. In case you want to perform a clean install (format hard drive and install a new windows...note that you will lose data so i suggest doing a back-up first), connect your usb drive to your laptop and put in your cd installer. Restart your laptop. When you see the dell logo, press F12 then release. (you have to really watch for it as the alloted time to do so is very small as you may have already noticed.) keep doing the press and release on the F12 key until a boot menu appears. Use your arrow keys to select the boot device to boot from (in this case, your external dvd drive)...
2. If that does not work, restart your laptop then go to the setup by pressing F2 when you see the dell logo (again, you really have to watch for it). when you are in, use arrow key to navigate to "system". press enter to expand the selection. Then use the arrow key again and select boot sequence. press enter. on the right side of the window, you will see the list / boot sequence. use arrow key to select usb external storage device. Then press U to move it to number one (see bottom screen for menu on navigation). When it is on number one, press enter. This will take you back to main menu. Press Esc key then choose save and exit. Your Laptop will then restart on your usb drive...watch for the "press any key to boot from cd..." then follow the instruction on windows 7 installation. Hope that helps...
Posted on Apr 22, 2011
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
"asus" laptop boot from bios
Hi.
If you are trying to install Windows 7 from the USB flash drive then you need to configure the drive so the system will see it as a boot drive, see link below for instructions on how to do this. If you have Windows 7 installed on the flash drive then the boot files may have become corrupt thus preventing you from booting into the operating system. Link for installing Win 7 from USB below >>>>>
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Regards.
Feb 04, 2013 | ASUS Computers & Internet
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
How to boot my laptop into usb drive
You have not specified your operating system. However I will explain how to do it with windows 7. First you have to create a bootable flash drive. Do it as follows
Format USB flash drive to NTFS format(For Win XP only. Vista users can directly format the USB drive to NTFS format) In your Windows, go to Control panel -> system -> hardware -> Device manager.
Under the disk drives section, right click on the USB storage drive and select Properties.
device-properties.pngGo to the Policies tab, select optimize for performance. Click OK.
device-policy.pngOpen your Windows Explorer, you should see the USB storage drive in the inventory. Right click and select Format. Select NTFS from the drop down bar. Click Start.
format-ntfs.pngFor Windows XP,
Download MBRWizard. Extract the zipped files to your desktop.
Open a command prompt (Start -> Program -> Accessories -> Command Prompt).
cd Desktop/MBRWiz2.0/
MBRWiz /list
Record the USB flash drive disk number
mbrwiz-list.pngMake the USB drive active.
mbrwiz /disk=X /active=1
For Windows Vista,
On the Start menu, navigate to the command prompt entry. Right-click and select Run as administrator.
vista-command-prompt.pngType
diskpart
list disk
Record the disk number of your USB flash drive.
vista-diskpart.pngSelect the USB disk.
select disk X (X is the drive number of the USB flash drive)
List the current partition. Record the partition number.
list partition
Select the current partition and make it active.
select partition Y (Y is the partition number of the USB flash drive)
active
list-partition-vista.png Creating bootable USB flash driveDownload Windows 7 iso (32-bit) file to your desktop (The download link is no longer valid).
Download and install WinRAR.
Right-click on the Windows 7 iso file and select Extract files. Extract the files to a folder (you can name the folder any name you want, but for illustration purpose, I name it win-7) in your desktop.
extract-win-7.pngIn your command prompt, cd to the windows 7 folder.
cd Desktop/win-7 (Change the destination to the folder that you have extracted)
cd boot
bootsect /nt60 X: (X is the drive latter of your USB drive )
bootsect-success.pngNow, copy all the files from the Windows 7 folder to the USB flash drive.
Reboot the computer. Remember to change the first boot device to your USB drive in the BIOS.
You should be able to install Windows 7 from your USB flash drive now.
Apr 26, 2011 | Sony Vaio Pcg-Z505N/Bp...
I installed windows 7 to my dell latitude d430 which had xp oringinally it is not reading or detecting the external drivers cd/cdr/dvd
Feb 01, 2010 | Dell Latitude D430 Notebook
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
Dell Latitude D430 Notebook Logo
983 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
