Question about Sharp AL 1215 Black and White Copier
Dark edges My AL-1540CS makes good copies but one edge of the print is dark where it has printed. I am using a reman toner cartridge. Could that be the problem?
  • Guy Davie Oct 25, 2008
    The problem occurs when I porint from the computer or make copies. It happens to a lesser degree when I use the document feeder but it still happens.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Posted on Oct 25, 2008
  • 1 more comment
  • Mike S
    Mike S Oct 25, 2008
    One more test
    If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass (that little bit of glass), and try again...
    For some reason they censored ****?
  • Mike S
    Mike S Oct 25, 2008
    If this happens when you print from the computer, it is internal, you have toner or devleoper dumping.
    if you open the cover where you put the toner in, and find toner every where. You probably need a PM call an authorized Sharp service tech to do this for your..
  • Mike S
    Mike S Oct 25, 2008
    or the charge could have dirt/dust on it, still it is internal..
Wen i print, there's a dark streak down the left edge of the paper. Hw do i solve this problem?
Hello, this one is fairly simple to diagnose, Change the toner cartridge, does the problem go away? if yes the toner is the problem. If the problem remains it would most likely be the fuser, in which case it would likely need servicing and the fuser replaced.
Jan 14, 2011 | HP LaserJet 1020 Printer
Help! My machine won't copy or print
check the old cartridge was empty or it was just showing wrong indication.( flashing ).
Aug 29, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Prints on my Lexmark T632 have a dark line running from leading to trailing edge of the paper. Toner cartridge replaced but didn't help. Lots of toner scattered through out the printer.
Great job on replacing the toner cartridge. Most probably problem's on the fuser or the charge roll. They may need to be replaced. But also check maintenance count to see if you have already reached the 300,000 prints. It affects the print quality when you have reached the limit.
Jun 24, 2010 | Lexmark T632 Laser Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
I am getting a 5mm dark bar on the lead edge of a print job
try drum refresh and developer refresh... make sure your firmware is current... if possible reset your print card... physically and software wise... make sure that the guides on your paper trays are a good fit... change the default paper tray for print jobs and see if that helps... if it does... then its the tray... if not then call service...
Dec 12, 2009 | Canon imageRUNNER 2200
Black edge on one side of printing
90% of the time this is your toner cartridge. Remove cartridge. Turn it over and slide open the protect plate. You will probably see the same "dark edge" of toner on the drum. You can verify by changing the cartridge. Even if you have an old one laying around you can shake up and try to see if the edge goes away.
Dec 07, 2009 | HP LaserJet 4 plus Printer
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Sharp AL 1215 Black and White Copier Logo
179 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
