Question about Necchi 3537 Mechanical Sewing Machine
Necchi 535 fa thread gets caught on the bobbin arm(?)
How do I sew if it keeps getting caught on that little arm that sticks out of the side of the bobbin case?
  • Anonymous Dec 20, 2008
    While the needle thread is fine and tight enough, the bobbin stitches are almost always ridiculously loose, regardless of the bobbin tension. It's driving me crazy! The thread then gets caught in the bobbin and I literally have to pull the fabric from the machine in order to get it "uncaught." I'm seriously considering buying another machine.
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
  • 323 Answers
SOURCE: Bobbin Case will not snap into housing
Insert the bobbin case without a bobbin to see if it will go all the way into the locked position. If it does,the bobbin case and basket are okay.
Check inside the bobbin basket(where the bobbin goes) and see if there is thread or lint wrapped around the spindle the bobbin case sits on. If there is, remove it. If there isn't ,then the bobbin is probably sprung and needs to be replaced.
sewman7
Posted on Oct 14, 2008
  • 9 Answers
SOURCE: how to thread my 535fa
I don't even know where to start. Send me you're email address and I'll get back to you with my phone number as I don't want to post it for the world to see. I'll be able to talk you through it.
Posted on Feb 21, 2009
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
SOURCE: I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Posted on Aug 01, 2010
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
I have a circa 1962 Elna and the thread keeps tangling under the pressure foot by the bobbin. I have rethreaded it twice as per instructions in the owners manual and still is happening, any suggestions?
if you are getting loops on the underside of the fabric or jamming around the bobbin, then your top thread is not under tension or going through the thread take up lever, that little arm that moves up and down. Recheck your threading path making sure you always raise the presser foot to open up the tension discs so that the thread lies into the tension discs fully. Also check that you have the bobbin threaded up correctly into the bobbin case, with the thread caught into the tension spring (you will hear a little click as it goes in). The bobbin will turn anticlockwise as you draw thread out of it. Use the top thread to raise the bottom thread up, replace the needle plate and bobbin case cover in place, then take both threads to the back of the sewing area. Hold them firmly as you start sewing! very important that you don't allow the thread tails to be caught and dragged into the bobbin as they will jam around the rotary hook.
May 05, 2014 | Elna Sewing Machines
Question about Necchi 537 FA
necchi's are good sewing machines, I personally own 2 necchi's,
and I've never had any problems with them and I've had them for around 10 years, here is what I suggest
use a new needle--one that is for the fabric your sewing
rethread the machine top and bobbin--use every thread guide
try a different bobbin
clean under the needle plate and in the bobbin area for lint
call a sewing machine repair shop in your area and ask them how
much a necchi sewing machine is worth or check on ebay and see
what they are selling for.
since you inherited the sewing machine,, having the machine
serviced completely would be a good idea, that way they can check
to see if the grease and oil that the gears and parts use is fresh or
needs to be replaced and it's very important the grease and oil are in
good condition.
and they can make sure the machine's is timed correctly
ask how much a tune up cost for a sewing machine and then
you'll have to decide if the price is what you want to pay.
also since the sewing machine is doing repeat loops from the bobbin
adjust the top thread tension just a little at a time till the stitch looks
normal on a scrap piece of fabric
if you don't have a manual on the sewing machine let me know & I'll try
to find you one.
I've been sewing for 30 years, and like I said I have 2 necchi's already
and I had one other one before these 2 that I have now and it lasted me
for around 15 years and I wore it out making clothes.
I wouldn't hesitate to buy or except another necchi because I know
they are good machines.
I have a mechanical and a electronic necchi and my husband uses the
electronic one when he makes quilts.
good luck on your decision
Merry Christmas and A Happy New Year
Dec 17, 2012 | Necchi 3537 Mechanical Sewing Machine
Jul 30, 2010 | Necchi Sewing Machines
Model 575 FA .. Haven't had it open in a long
Take out the bobbin and bobbin case and check round the raceway, chances are you have a small piece of thread stuck
Oct 25, 2009 | Necchi Sewing Machines
Thread caught in hook race
There should be a small screw on the side of your bobbin case adjust it little by little until you get the correct tension.
Jun 06, 2009 | Euro-Pro 9125 Computerized Sewing Machine
How to thread my 535fa
Feb 20, 2009 | Necchi 3537 Mechanical Sewing Machine
Necchi 525 FA model
This site (www.sewusa.com) sells manuals for many types of sewing machines. It also has a section (on left side of home page) that provides basic information about treading (bobbins too) and repair.
I also own a 525 FA and just read that someone considers it is a piece of junk. I'm having problems with the tread breaking constantly (with many hours spent on this problem) and I even have a manual! Perhaps it is a piece of junk?
Marla
Jul 15, 2008 | Necchi 3101 Mechanical Sewing Machine
Necchi 3537 Mechanical Sewing Machine Logo
353 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
