Problem; my NEC plasma has 30 to 40 mullty coloured vertical lines.
  • adam_saiti Oct 25, 2008
    my NEC plasma PX-42VP4G/S has approx.40 v ertical lines mullty colours (top to bottom)
  • 320 Answers
It could be either the plasma panel itself has failed or one of the driver boards has either failed or has developed a poor solder connection where it connects to the panel. Unfortunately, because of the high voltage contained in the unit, I cannot suggest you attempt service yourself, as there is a real shock hazard. You will have to contact a servicer to look at your TV. Sorry!
Posted on Oct 25, 2008
  • Any Guy
    Any Guy Oct 25, 2008
    I still think my previous posting is correct, either a bad plasma panel, bad driver boards and/or poor solder connections. Sorry if this isn't the solution you're looking for.
  • Any Guy
    BTW your unit doesn't have a convergence IV on the power supply or anywhere else for that matter.
    Scholar:
  • 136 Answers
Its the problem in your convergence IC on the main power supply board.
  • ready2helpu Oct 25, 2008
    get it replaced or repaired.
    you can do it your self if you have any technical knowledge.
    you can get the required IC at
    www.radioshack.com
    thanks.
    sometimes it also happens doe to heavcy voltage passed through the electrical line from which your tv is connected.
    so if this is the cause
    you can off the tv unplug the device from the main power socket and leave it for 10 minutes.and then connect it somewhere else and then try.
    if due to heavy voltage passed this happened it will resolve after you plug it again.
    thanks.
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
Nec Plasma having vertical line red colour thin line how i m resolved that issue can u help me.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Televison & Video
My NEC LCD monitor suddenly starts 'weeping' and I get vertical black and white lines from the left up to middle of the screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem....
Jun 15, 2011 | NEC 50XR5 50 in. HDTV Plasma Television
Cracked plasma screen
A plasma display is a very expensive part to replace. When the plasma display is broken, the tv is usually not worth repair.
Call Nec at the number listed on the owner manual, and ask a quote on part or repair.
Regards.
Jul 11, 2009 | NEC - 42" Commercial Plasma Screen ****(no...
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Oct 07, 2006 | NEC PlasmaSync PX-42VM2A Television
Televison & Video Logo
Top Televison & Video Experts
