When i go to start the computer (laptop), the normal HP symbol appears, then is says 1) fix problems (reccommended) and 2) start normally.. and at the top of the page says there is a possible error with the harddrive...... i click the reccommended one, it opens, goes through the normal microsoft icon, then turns to a bluish screen without any further function.
  • 43 Answers
What error message is on the blue screen?
It is possible with a windows disk to do a repair on the operating system without losing your data and programs. However if the hard drive is crashed (physically damaged), the repair mentioned above won't save it.
Some HP's have a built-in restore of windows, accessed by a function key, but beware, it may erase the hard drive before the re-install of windows.
Posted on Oct 25, 2008
Symbol @ from my hp is different i can not type
I had that problem before. When i installed windows 8 to my laptop, the keyboard goes that way. Try to click the key from what was the symbol appeared instead while you were pressing the 2 or @ key. Maybe they're switching each other...I cant find what was the reason why it happened, maybe the compatibility or driver issues. When i turned WIN 7 OS back...the keyboard works normally again.
Sep 03, 2014 | HP Computers & Internet
HP Pavilion dv6-2190us screen blank, all lights on. No worky. Any suggestions?
Based on your description, it is recommended that you refer to the following information:
You can start (or restart) HP (COMPAQ) appears, stop clicking F8 keys the view safe mode is normal.
1 If safe mode normal, you can turn to test the following method:
1) Device Manager to roll back the driver or reinstall the driver test.
2) the new account in safe mode and test disable startup items (click on the lower left hand corner of the keyboard and the Windows logo key R calling Run, type msconfig command, go to "Start" to remove unwanted boot automatically start the program in front of the check mark ).
3) backup data, reinstall the system.
2 If safe mode is not working properly, you can try to save important files after format hard drive to reinstall the operating system under to see if you can solve the problems you encounter.
Reply to help you more than friends, I hope
If you need to work from a trusted retailer of batteries, you know, you do not wrong by choosing
laptop-battery-adapter.co.uk or laptopbatteryinc.ca. Because the products we offer absolutely cheap, high-quality, 100% safe, 100% compatible, 100% satisfaction.
Mar 15, 2013 | Computers & Internet
My hp pavilion dv6 laptop startup process, every other process even media player also very slow speed is working . how can i solve this kind of problem?
1) you NEED tune up your computer.Normally the computer has integrated the software for solution and get integrated the software diagnostics, and TUNE UP use it.
2) uninstalled programs
3) clean for cookies,etc
4)updated your computer from window
5) pass the AntiViurs +Malware software
6) pass the Check disk from your local disk, etc
Try it , otherwise you must go to the repair shop computer for fix it.
Sep 25, 2012 | HEWLETT-PACKARD HP Pavilion DV-61053CL...
Laptop emits continuous stream of beeps and loads advanced boot options page.
there is couple reason for that. (1) start windows normally and restore the system at previous stage. so if some driver software conflict with hardware then it solve problem. (2) insert the os disc and boot from the disc and choos repair \restore operating system. it may replace any missing system file. (3) if 1st and 2d not solve the problem then remove the RAM and clean it and fix it again. or check SMPS or Hard drive...
Jul 09, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
HP Pavillion DV2000 (dv2415)laptop w AMD Turion64X2, running Windows Vista. The problem appears to be a power up issue where, when the laptop is initially turned on, all the various lighted buttons around...
We can troubleshoot the Overheat issue but first we need to turn it on. Perform following steps and check if you can see the diplay on screen.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the Notebook power up and shows you display, then proceed with further steps (or you can connect a desktop monitor to check if its displaying. Press Fn+F4 to toggle the display on external monitor)
The notebook may overheat and make noise or stop working due to the following conditions:
1. Due to incorrect power supply from the AC adapter.
2. If the Fans/Heat Sink are not working properly.
3. If the power management and BIOS settings are messed up in the Notebook.
4. Finally due to other components on the system board.
To resolve this problem with overheating, perform following steps.
I check your Laptop and see that your Laptop product number is "GA534UA#ABA" with Windows® Vista Home Premium pre-installed, if you are using the same, process with following steps.
Step 1: Reset the BIOS to factory defaults:
1. Click Start, Turn Off Computer, Restart.
2. When the HP logo appears, press F10 to enter BIOS Setup.
3. Press F9 when you are in BIOS Utility to load the BIOS to default. Click YES. Then press F10 to Save & Exit.
Step 2:Re-install Power Management in Vista
1. Press Windows key + R
2. Type devmgmt.msc and press enter.
3. Click the plus (+) sign next to System Devices.
4. Right-click the ACPI Fixed Features button and select Uninstall.
5. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
Step 3: Installing an update for BIOS:
Caution: Install this BIOS only if you are using pre-installed operating system with above mentioned Product number.
WinFlash for HP Notebook System BIOS (for Notebooks with AMD Processors):
ftp://ftp.hp.com/pub/softpaq/sp43501-44000/sp43666.exe
Step 4: AirVent cleaning:
Reducing Heat and Fan Noise by Cleaning Air Vents:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01657439&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
In case there is no display, remove and reseat the Hard Disk and RAM and check for the issue. If display comes up after removing and reseating the RAM and HDD, then you need to follow the above steps again.
Service Manual to remove reseat HDD and RAM:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Memory Module Page: 127 of 310
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Hard Disk Page: 121 of 310
Contact HP at www.hp.com/support/chat for further assistance.
Aug 22, 2010 | HP Pavilion dv2415nr Laptop
On starting my laptop i keep getting the "Windows Recovery Error" screen with the option to select 1. Start windows repair (reccommended) 2 Start windows normally However selecting either of these results...
Have you gotten any help yet? Check to see if it's a bad driver (or incompatible driver). The prob you're having is common with a new driver that isn't compatible with your system.
May 12, 2010 | Acer Aspire 6920 Notebook PC
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
2-Without navigating to another open window, press Alt and Space bar at the same time.
The Shortcut menu displays near the top-left corner of the computer.
Figure 1: Shortcut menu
If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
3-Select Minimize from the Shortcut menu.
HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen).
If HP Director does not minimize, click Minimize again until it does.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Jul 16, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
