Question about Toshiba Satellite M35X-S349 Notebook
Laptop fan My toshiba satellite fan doe not seem to be running like it use to. the temp gets to 106 , running at 104 now, the fan does run when booting up with the xp screen showing
  • 737 Answers
Hi. The common problem with these is dust build up in the heatsink fins, but I would have thought the fans would be runnnig hard. try cleaning the dust out by putting a vaccuum cleaner against the grills and around the fan intakes. apart from that, they can have fan failure when trying to run at idle speeds (they may still work at boot) - especially if the fan(s) were running with a slight rattle previously.
Mark
Posted on Oct 25, 2008
Toshiba satellite a100-153 running hot
Something is very wrong here. Does this occur when running on internal battery or only when plugged into the power adapter? At these temperatures the cooling fan should be running at full speed constantly until the temperatures fall to about 50 centigrade or lower. (dependant upon loading and CPU power consumption.) The laptop should automatically power down at the temperatures you are quoting!
Apr 08, 2014 | Amstron Toshiba Satellite A100-153 Laptop...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
The fan on my satellite L645D-S4050 runs constantly and drains the battery very quickly. Battery life is about an hour as opposed to the advertised 4 hours. I have seen mention of installing and...
First Visit http://support.toshiba.com up top Click "Download" and search out your Toshiba Model Laptop. You could try a BIOS upgrade for it, it won't hurt anything, but I seriously doubt your fan is draining the battery that fast, even if it does run all the time. It's possible there is dust in there causing the fan to run all the time, or your power management settings need adjusting. Although the BIOS upgrade, if applicable, may help the fan, and should, frankly, be run anyway if available. I'd be seeking another battery to try, or maybe just buy a new one. If you get 4 hours you're good to go, from my experience laptop batteries die and just need replacing.
Sep 09, 2011 | Toshiba Satellite L645D-S4050 Notebook
My Toshiba satellite A205-S5804 laptop keeps losing power randomly with battery at full and the AC cord plugged into it. I also have a external fan unit to keep the laptop cool but to no avail. What could...
get the download core temp off cnet.com
download and install then run it
watch your cpu core temperature
set a warning in the core temp features to alert by alarm when the temp gets above say 80 C
if it hits 80C.. its running too hot
Jan 21, 2011 | Toshiba Satellite A205-S5804 Notebook
My Toshiba Satellite Laptop M105-s3004 Crash and fan not running
Because the fan doesn't work, your laptop is overheating and going into thermal shutdown. have the fan replaced and the area where it is screwed to cleaned as it harbours dust over time preventing adequate cooling.
Jan 25, 2010 | Toshiba Satellite M105-S3004 Notebook
Running high temps
For the best cleaning you should take the laptop to a service. If you open by yoursefl and cleanit you have a good chance to not mountit 100% good. Do not try to use a compressor to blow air on the laptop because you can break the coolers
Jul 14, 2009 | Toshiba Satellite P205D-S7802 Notebook
Overheating trouble?
It sounds to me that your laptop fan is either clogged with dust or the bearings have jammed. Its most likely going to be necessary to open up the laptop and clean or replace the fan. This will require an experienced technician to avoid risking further damage. I have done it and its tedious at best. No other solution will work.
Dec 20, 2008 | Toshiba Satellite A215-S7422 Notebook
My laptop Toshiba Satellite A205-S4577 does not re-boot
start the machine and immediately press the setup button to get bios setup options. In this you have to set the cd/dvd as the first booting device. that's all. good luck.
Dec 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Fan noise
Is the fan making an unusual noise or just sounding normal but on more then it used to be? If its just on more than it used to be then it will be because the cpu is running hotter than it used to. They are set run at diff speeds depnding on how much cooling is reqd. Is the laptop being used in a warmer place than normal/before?
It may be that the thermal paste between cpu and heatsink isnt performing as well as it used to and needs replacing.
Feb 02, 2008 | Toshiba Satellite A135 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
263 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
