Question about Frigidaire FRS26R4A Side by Side Refrigerator
Fridge smell Yesterday our electric went out for about five minutes and came back on, everything was fine. In the middle of the night last night, my dad said his light flickered and he went out into the kitchen a little while later and noticed the fridge was off so he flipped the braker and turned it back on. When we woke up this morning, our whole house smelled like chemicals, almost like super glue and it's coming from the fridge, we turned it off now, but it smells soooo bad, it didn't go away all day and i'm scared of what it could be
  • 903 Answers
Check the pipes at the back of the fridge, it could be that one of the pipes has a crack and is leaking gas or oil. If not check the inside of the fride for a brown oily residue. This indicates a leak. Don't turn the fridge back on becasue if the oil and gas mix then the fridge will no longer be usable. If you find either of these get an engineer to fix the problem.
Posted on Oct 25, 2008
Hi i bought a vw beetle was running fine the last few days. I went to drive it yesterday and it wont start the immobiliser is showing its not flashing tho. My step dad replaced the car keys battery the day...
My immobiliser keeps flashing until I put the key in the ignition and then it stops. Normally changing key batteries has a period that if the battery is changed inside that time (say 5 minutes) then the key program will not loose memory Run fault codes to see if there is a problem in the electronics. Otherwise you may have to take the car to the dealer to have the key reprogrammed to the cpu in the car
Sep 28, 2013 | Cars & Trucks
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
My 96 grand cherokee is shutting down,have replaced almost everything but crank sensor will this be the end of my problems???please help
If the crank sensor is failing, you should get a check engine light and a trouble code for it.
Have you had the computer checked for trouble codes ?
Aug 17, 2012 | Jeep Grand Cherokee Cars & Trucks
Electrical short?
dash short or lighting stalk
Aug 16, 2012 | 2000 Toyota Camry
Xbox 360 is freezing with no red rings and an intercooler?
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
As long as you stop most of the heat getting to the GPU and the CPU you will be fine.
Feb 22, 2010 | Microsoft Xbox 360 Console
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Frigidaire FRS26R4A Side by Side Refrigerator Logo
402 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
