Question about Canon BubbleJet i550 InkJet Printer
Cyan does not print
My Bubblejet i550 does not print cyan at all. I have tried cleaning and deep cleaning and nozzle check but still no cyan. Please someone help. Thank you.
  • GenTaur Oct 25, 2008
    Well Weblord, the ink cartridge is full, in fact it is new, with yellow tape completely removed and the plastic on the bottom removed as well.
  • 507 Answers
Have you considered it might be empty and time for a replacement?
Posted on Oct 25, 2008
  • William Nabaza
    William Nabaza Oct 25, 2008
    what could be happening is the contacts between the cartridge and the
    holder could be clogged with ink, causing the signal to the cartridge
    to be lost.
    what I suggest you do is, get a q-tip with either some rubbing alcohol
    or distilled water. Remove the print cartridge, power off the printer,
    and rub the gold contacts on both the cartridge and the contacts on the
    inside of the carraige cartridge holder.
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Dell 3150 printer printing cyan streaks
This could be caused by some of the ink jets on the cyan print head. Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 10, 2012 | Dell Office Equipment & Supplies
No cyan on photo
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 16, 2012 | Canon PIXMA MP620 All-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Wrong colour
Have you done the nozzle check print? It would show if any colors are missing. While ready with the green light on, press and hold the resume button until the green light flashes twice and release, it will print the nozzle check. You also can't use the photo magenta or photo cyan in this machine, you need the regular cartridges.
Oct 08, 2009 | Canon BubbleJet i550 InkJet Printer
MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Sep 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Cyan ink tank not printing
clogging in cyan nozzles in printhead. try to clean or deep clean printhead from printer software.
Sep 17, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon BubbleJet i550 InkJet Printer Logo
82 people viewed this question
old marine
old marine
