Question about Philips Audio Players & Recorders
Philips Home Theater System HTS3540 - Philips Audio Players & Recorders
pgh_pa_guy
  • 2992 Answers
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
SOURCE: No code for my RCA DVD HTS on my Philips Universal Remote.
does anyone have a fix for this problem, i have essentially the same problem, my remote is the phillips sru5107/27
Posted on Aug 13, 2010
SOURCE: Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen ]
from http://www.videohelp.com/dvdhacks
Posted on Aug 21, 2010
Stuck on standby and wont open to remove dvd
Try a hard reset. If it do now help, the main system control memory I is faulty. It should be replaced. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 05, 2015 | Philips hts3540/98 code free dvd home...
How to update the software of philips SW9810
There is no firmware for this model. Yu can check yourself on this link.
Find your product
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Aug 02, 2014 | Philips hts3540/98 code free dvd home...
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
Philips home theater system
Make sure there is a video cable of some type running from the back of the Philips to the television, and make sure the TV is on the correct source channel. Make sure the home theater system is in disc mode.
-Tha Mp3 Doctor
Dec 08, 2008 | Philips HTS3450 System
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
