Question about Ovens
Lamona User Manual HJA 3400 - Ovens
Hi, i need a instruction manual for Lamona double electric oven HJA4620. thank you
Try Googling (lamona)(HJA4620)(manual) without parens.
May 07, 2017 | Ovens
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
Got a fan assisted oven Lamona 3400 in operation back heats up front dont?
does it use different elements for back and front? check for continuity. is fan working properly?
Mar 10, 2015 | Ovens
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
Model HJA 3220 removal of internal glass panel
i have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Feb 18, 2012 | Ovens
Ovens Logo
480 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
