Question about D-Link DPH-50U IP Phone
DPH-50U driver using high DPCs
My PC has been rather sluggish. I did some testing. I found the culprit to be the driver for my DPH-50U. When this driver is enabled my DPCs go through the roof. Way too high. Making my CPU usage abput 30% even when my system is at idle. As soon as i disable the driver the DPCs go down to almost zero.
I am using the latest driver from D-Link. I sent a email to D-Link support. Didn't get an answer yet.
Try testing thison your PC running XP. With no programs running, open windows task manager and clickon the performance tab. You will see CPU usage is between 17 & 30%. It should be 0 - 3%. Then, go into the device manager and right click on the dlink VOIP device and select disable. Then check your CPU usage. You will see a dramatic reduction of cpu usage when system is at idle.
I'll let you know if I hear anything from d-link about this problem.
  • base16hex-3 Nov 17, 2008
    Same deal. I uninstalled the DPH-50U and now back down to usual.
    I was running to 405
I had the same problem. Here's what I did to fix it. Unplug device. Download the v1.1 of the software, extract to a directory, run setup, when prompted for the drivers, point windows to the directory I ran setup from. Finally, I plugged the device into a usb port directly on my laptop (rather than through the port replication). Some combination of all that made the situation much better.
Posted on Oct 15, 2009
  • 16 Answers
I had a similar problem on a pc i built. the culprit was my wireless card. i opened up the pc and moved the card from one pci slot to another. powered it on and it redetected mt card. my cpu usage went from 40-50% at idle to 0-5% depending. hope that helps
Posted on Jul 07, 2009
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
I have installed Skype 3.8 and d-link driver 1.01 on Windows xp. I can select the device from the audio setting but receive no dial tone. Please assist!
In your VoIP monitor settings there are two options to make your phone connect to voip. You either have to dail # # or # *. I would try hitting pound twice, but it's kind of tricky because sometimes when the dlink tries to connect it will flip back and forth between voip and pstn. So I recommend holding the phone to your ear and hitting # until you hear that dial tone!
Jul 01, 2010 | D-Link DPH-50U IP Phone
Need to connect my landline to skype
No Skype is DIGITAL all fax machines are ANALOG.
Jul 07, 2009 | Brother MFC 240C All-In-One InkJet Printer
Using the D-Link skype/pstn switch with a SIP account
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
DPH-50U can't be uninstalled or reinstalled correctly
To solve a problem "device not present", you must delete registry key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{55280429-413e-460f-a31a-e19314823119}\0001" and restart service "VService".
Dec 14, 2008 | D-Link DPH-50U IP Phone
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
How to do voip calls with the regular phone
Did you read the manual?
first you press ##
then you will hear a weird buzz
then you dial 00 and then the phone number including the country code (example in canada.. you will do 00 1 450 419 0000
then you press *
so again,
## (weird buzz) 00 1 450 419 0000 *
and wait few seconds
Nov 15, 2007 | D-Link DPH-50U IP Phone
D-Link DPH-50U IP Phone Logo
667 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
