Question about McCulloch Garden
I have a mac3516 chainsaw bogs when i turn choke off
Chainsaw wants to die when i turn my choke off or bogs way down and wont turn chain till i turn choke on half way do i need to adjust the high or low adjustments or the timeing or whats my problem its a macculloch 3516
    Novelist:
  • 99 Answers
Generally you shouldn't have to adjust the carb settings. It is probably due to an incorrect air/fuel ratio but could be caused by a few different things. First of all, check your air filter and clean if needed. If this is ok then you might have an air leak some where. Make sure your carb is screwed tight onto the machine and that all the gaskets and manifolds are fine. If there is a rubber tube going from the carb to the cylinder, put some soapy water on it and check for bubbles. If you see any then there is a compression leak and this is the cause of the problem. Other wear parts that may develop an air leak are the crank seals and piston rings. These would be best checked at a workshop where they can do full pressure testing. One other thing to chceck is the exhaust. Most exhausts have a spark arrester. This is a bit of gauze on or near the outlet. If this becomes to dirty then it can affect the performance. It is normally easy to remove, clean and refit. You could also take the exhaust of and make sure it isn't too 'coked up' with carbon. While the exhaust is off, just check through the manifold and make sure there is no scoring on the piston or cylinder as this would also cause pressure leak. This would only happen if you have been using dirty fuel, fuel without the correct oil mixture or if the cooling fans on the cylinder are blocked.
One last thought, and it is a fairly common one in my workshop. Old or stale fuel will not burn efficiently. If you have a quick sniff and it really hits the back of your throat then you might need to put some fresher stuff in and give it another go. You would be shocked at the amount of gardening equipment we get in that has been layed up over winter with the fuel in that won't start in the beginning of spring/summer.
Posted on Oct 26, 2008
I have a mac3516 chain saw. How do I repair, replace tang or bar adjustment?
McCulloch MC3516 Chainsaw
not unusual you cant buy what you need .. for a McCulloch
its policy is Please do not return product to retailer
your options
look around for another mac3516 for parts or fabricate you own
a user manual . 20 pages.entered sideways
http://lawnandgarden.manualsonline.com/manuals/mfg/mcculloch/mc3516.html
Apr 03, 2016 | Garden
How to adjust carburator on a mac 130 chain saw
turn till it stops clockwise, then turn back counter clock about 1 1/2 turns. If you hear the motor sounding bogged down, turn it a bit more counter clockwise, (leans out the gas) till it stops sputtering .
Jun 21, 2014 | McCulloch Garden
Starts with choke, disengage choke , runs a short while, then sounds bogged down & dies.
Could be a couple of things. First guess is the carburetor is bad. Because when the saw goes from the choke circuit to run it dies.
Apr 20, 2014 | Husqvarna Garden
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
Mac3516 chainsaw wont start in the shed for 2 years pumped the gas choked and started ran out of gas filled with gas and oil then it would not start
Have you checked the spark plug? and did you try moving the switch to differnet setting like half coked full coked?
Mar 07, 2010 | Garden
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Garden Logo
279 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
