Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
How old is my battery
P104 #130429001
  • Ryobi Master
  • 885 Answers
On the bottom of your battery there's a serial number, look at the four numbers that follow any letters, one or two if any. The first two numbers are the year the battery was made, the second two are the week it was made. If your number was 0610, it would have been made in 2006 on the 10th week, about the 2nd week in March. These numbers reflect the date the battery was actually made and rolled off the assembly line. It does not take into account how much time the battery sat in a warehouse or in a The Home Depot before you bought it.
Posted on Feb 15, 2012
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
My CK 2247107 watch is one year old now, Suddenly the watch stopped running, Surely cannot be the battery. Do i need to change any mode. I tried setting different modes on the pushbutton to reset the...
mcdevito75 here, One year old, most likely the factory Battery and at 1 year old the battery is old, who knows how long the battery was in the watch before you bought it 1 year ago?? The battery is the first suspect. Look for a small watch repair shop in your area for a new battery first.
Feb 09, 2011 | Watches
Will not star or turn over.
CHECK BATTERY CABLES MAKE SURE THEY ARE NOT CORRODED AND LOOSE.ALSO CHECK BATTERY VOLTAGE.SHOULD BE 12.6 VOLTS IF NOT REPLACED BATTERY.BEFORE REMOVING NEGATIVE BATTERY CABLE TURN OF RADIO FIRST.AFTER INSTALLING NEW BATTERY.WITH ENGINE RUNNING CHECK ALTERNATOR OUT PUT AT BATTERY SHOULD BE 13.5 TO 14.5 VOLTS.DOING THIS WILL MAY SURE BATTERY GETTING GOOD CHARGE.2 REASON BATTERIES STOP WORKING.THEY FAIL FROM OLD AGE AND ALTERNATOR CHARGING SYSTEM NOT WORKING.IF BATTERY CABLES VERY OLD I WOULD REPLACE THEM.THAT WILL HELP BATTERY GET BETTER CHARGE.OLD BATTERY CABLES PUT A RESISTANCE ON CHARGING CIRCUIT CAUSE ALTERNATOR WORK HARDER TO KEEP BATTERY CHARGED WHICH WILL SHORTEN THE ALTERNATOR LIFE.
Jan 26, 2011 | 1999 Oldsmobile Alero
BAttery problems - my Xog only lasts about 10 minutes. Is there a replacement battery that can be purchased?
A battery that will fit is available http://www.batterybob.com/product.asp?intProdID=661221
The good news is that it has 25% more power than the original. The not so good news is that you will have to replace the plug on the new battery with the one from the old battery. If this is not something you want to attempt take the old battery to Batteries Plus, they will sell you a new battery and take the plug off your old battey and put it on the new battery.
Jan 11, 2011 | Lowrance XOG GPS Receiver
Goes from fully charged to almost zero charge in seconds
HI,
Please make sure the charger is working.I suggest you try replacing it with a new charge and then give it a try.The problem can also be with the battery if it is more than 2-3 yrs old.In this case the problem is with the battery.
So i suggest if the battery is more than 3 yrs old buy a new one and then test it with the old charger and if the battery is not old then replace it with a new charger and try charging the battery.
Let me know the result
Jul 02, 2009 | Samsung BlackJack II Smartphone
UPS MGE problem
  1. old school hollywood baseball old school hollywood baseball old school hollywood baseball
  2. old school hollywood baseball old school hollywood baseball
  3. old school hollywood baseball old school hollywood baseball
  4. v
Feb 05, 2009 | Computers & Internet
To increase backup in apc symmentra ups
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | APC Symmetra Tune-UPS technical support -...
SOS!
replace the battery.
Jun 29, 2008 | LG CHOCOLATE VX8500 Cellular Phone
OPTi ups surge protector
clear and simple. the batteries are bad. they last about 3-5 years usually. "batteries plus" in your area will usually replace them and dispose of the old batteries. In the past I have replaced the batteries myself and taken the old ones to a battery surplus house and gotten a few dollars for the old ones (battery core).
Sep 10, 2007 | Opti -UPS PowerES 650 UPS System
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
805 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
