Question about Onkyo HTR500 Receiver
Onkyo HT-R500 no display
Unit works fine but the display is dark
Look on line for service manual. Display problem is usually traced to 1, or more, of 3 resistors in the AC supply to the display. It appears that the resistors are supposed to be 1/2 watt but the one I removed from my unit was only 1/4 watt. The resistors are mounted on a small board mounted on the front side of the main transformer - right most board. I had to unscrew the transformer to access the resistor. I looked at voltages coming out of the transformer and the the same voltages leaving the circuit board. There is a 1 Ohm, a .47 Ohm and another that supply AC voltage to different parts of the display. I found one resistor open. Replaced it and I now have an operating unit.
Posted on Jan 18, 2013
  • 134 Answers
SOURCE: onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Posted on Oct 02, 2008
petraman7
  • 1175 Answers
SOURCE: i have a onkyo HT-R500
A receiver that recent usually has a detect circuit that keeps the outputs off until speakers are connected . So, if it bows fuses right away , it's really a power supply issue.
Probably the AC rectifier bridge.
Tech service only.
Posted on Jan 01, 2009
  • 15 Answers
SOURCE: Can not get sound from my Onkyo HT-R500 when connected to direct
check the cable, or the settings on tv someone must move it and turn off the audio out.
Posted on Jan 12, 2009
lynchms
  • 93 Answers
SOURCE: connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Posted on Feb 28, 2009
  • 336 Answers
SOURCE: i have an onkyo ht-r500 and the lcd display has burnt out
The burn spot on the display tube is normal.
Check for dc voltage to the display first and last pins should be (-20v to -30vDC) to ground.Then check for ac voltage across the first an last pins of the display should be (3v to 5vAC)
If you are missing them check for open fuses or resistors often on a board on the main transformer. But there are several other possibilities (shorted diode, transistor, capacitor or open resistor).
Only a couple of times have I seen a new display fix it.
Always look for bad solder connections on the display.
As for replacement parts I dont know if they sell to the public or only to service centers.
Posted on Mar 13, 2009
How to setup
http://www.manualslib.com/manual/302221/Onkyo-Ht-R500.html
Jan 10, 2015 | Onkyo Ht-r500 5.1 Channels Receiver A/v...
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
I connected my Panasonic Plasma's optical out to my HT-R500 but it's not producing any sound... i tried several combinations of settings and none have resolved my problem.
Hi...To answer your question about your Sound issue...Try first, check if you have a muting volume control on your setting.. Also some unit, you have to set the date and time before anything... hi hope that gonna work good luck
Oct 13, 2010 | Onkyo HTR500 Receiver
How much did the onkyo ht-r500 cost new
I've seen one person claim that they paid $799 quite a few years ago when it was sold as new at the now defunct Circuit City.
Jul 01, 2010 | Onkyo HTR500 Receiver
I have an onkyo ht-r500 and the lcd display has burnt out theres a dark burn dot on th lower left corner of the display all other functions seem to be operating normaly where can i find replacement parts...
Mar 13, 2009 | Onkyo HTR500 Receiver
Connecting Sirus audio to Onkyo HT-R500
Feb 28, 2009 | Onkyo HTR500 Receiver
Dec 27, 2008 | Onkyo HTR500 Receiver
Onkyo ht-r500
Aug 06, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
329 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
