Question about Sharp Microwave Ovens
R-305K Sharp Microwave has the interior light staying on after the door is closed. On inspection, the top switch has nothing to trip the switch. Seems something is missing between the door latch and
Microwave is 4 yrs old. when the top switch is depressed with a screwdriver the light goes out.
  • Hazel Kirschenmann Feb 15, 2012
    I checked the spring in the door and it is fine.. The top hook does not trip the switch it should control. Part 4-9 on the drawing does not show any other parts that control the switch.
    Sniper:
  • 76 Answers
This could be caused by a faulty interlock mechanism. Check this first.
Posted on Feb 14, 2012
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Jan 12, 2009
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: door latch on sharp 1480 microwave over the range oven
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Posted on Sep 16, 2008
  • 8909 Answers
SOURCE: When I press start on my sharp R-305K microwave
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Feb 24, 2011
Ibought a new microwave today and after installing it the interior light stays on and the microwave doesnt start unless I open and close the door any ideas for me?
Take it back for a replacement. You have a bad door switch and it is not recognizing when the door is closed.
Semper Fi,
Z
Jan 31, 2018 | Microwave Ovens
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Microwave stopped working what can possibly be the problem
If it lights and the fan turns on, then most likely it is the magnetatron or heating element. It can be replaced.
Aug 19, 2014 | Kenmore Microwave Ovens
My GE counter top microwave will only count down. The light, fan, and turntable will not work. Lifting the door solution did not work. It's only 2 yrs. old.
I would suspect a door switch is defective or its mount is loose, misaligned, or broken.
See my he;p file on door switches here.
Dec 27, 2013 | GE Microwave Ovens
Microwaves fan and light on permanently
One of the relays is stuck. Hit it firmly and see if the fan turns off
Nov 28, 2013 | Sharp 2.0 cu.ft. 1200 Watt Microwave -...
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave does't make any noise ,,,but the count down on clock is working ...light is working but no fan ...or huming noise ...what could it be
HELLO.
The likely thing to be is that the microwave fan is faulty.the solution is to replace the fan.
Needed instrument:Phillips-head screwdriver.
Instructions on how to replace the fan is detailed given below.
    • 1. Unplug the microwave from the wall outlet to prevent an electrical shock while
    • working on the microwave oven.
    • 2 .Remove the screws holding the fan shroud to the top of the microwave oven. Using a Phillips-head screwdriver, turn the screws counterclockwise to back them out of the panel. Set the screws in a safe place so they will be available for installing the new fan.
    • 3.Slide the fan shroud--also referred to as a damper plate--forward, toward the front of the microwave, to remove it. Set the shroud to the side.
    • 4. Lift the fan assembly out of the microwave. An electrical cable and plug is accessible once the fan assembly is out of the way.
    • 5. Unplug the electrical connector from the fan and fully remove the fan assembly.
    • 6. Set the new fan assembly close to the top of the microwave to facilitate plugging the new fan into the microwave's connector. Plug in the fan assembly.
    • 7. Position the new fan in the same orientation as the old fan's before its removal. Lower the fan assembly into position.
    • 8. Slide the fan shroud in place and install the screws to secure the shroud.
    • 9. Tighten the screws with the Phillips-head screwdriver by turning the clockwise.
    • 10. Plug the microwave oven into the wall outlet and test the new fan installation.
Thanks
Sep 20, 2011 | Haier Microwave Microwave Oven
I have a KitchenAid KHMS155LSS that has a problem with the door interlock switch(es). When the door is closed, the interior light stays on (it thinks the door is still open). It appears that the plastic...
Its a little tricky but can be done from the front. First unplug the unit, remove the top grill (above the door), then there is one screw to the control panel (remove it). Carefully, push up from the bottom of the panel to release the control, inside your should see to screws holding the interlock switches in place, if the harness is long enough you can bring them forward to inspect.
Good Luck, be safe and unplug unit first..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
