Question about Neff B1451 Single circotherm plus Electric Oven
Self cleaned NEff U1422 electric oven now short circuits
barkencoa
  • 3463 Answers
SOURCE: Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
kibonghe
  • 25 Answers
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Posted on Feb 04, 2009
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
Maytag317
  • 1136 Answers
SOURCE: trying to unscrew bulb cover in a neff oven
Hi, DO NOT use WD40. Take a small towel or a rubber pad and grasp the lens with the palm of your hand. Turn it counter clockwise to release it.
It is very thick glass so, it should not break.
You might try to tighten it first. Sometimes a little nudge to tighten it will free it up.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on Jun 13, 2009
SOURCE: neff u1661n2gb/05. main oven not working and
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Posted on Nov 17, 2010
Neff u1422 oven where is the element that needs tobe cleaned
behind back panel in oven held on with several screws.
Feb 20, 2015 | Neff Ovens
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
Can NEFF oven be connected using a three pin plug on an independent oven circuit
If is a bog standard single oven then yes, if it has a self clean function or a rapid heat up function then generally no as the current draw would be to high for a 13amp to cope with, if you need model specific verification ring number as per linkhttp://www.neffcustomerservice.co.uk/Neff/CustomerService.html
Nov 26, 2011 | Neff Ovens
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Trying to unscrew bulb cover in a neff oven
no WD-40, turn of the power, break the bulb and remove the base with pliers. More than likely there is dielectric corrosion between the base and the socket and this makes removal next to impossible
Jun 13, 2009 | Neff U1721 Double circotherm Electric Oven
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Neff oven B1641
Feb 27, 2009 | Neff B1641 Single circotherm super...
Hi
Good luck
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Neff B1451 Single circotherm plus Electric Oven Logo
60 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
