Question about Royal Marines Commando - Windows for Windows, DOS
Enter password extrat file
Password for extrat file
It runs, but why doesn't it extract water?
The compressor has to run to extract moisture. You may be hearing just the fan running.
Nov 23, 2015 | Dehumidifiers
Tip
Want to find out your computers BIOS/CMOS password?
Forgot your Windows Admin/User password? Want to find out your computer's BIOS/CMOS password?<br /> This is the right tool for you!Works on USB drives too so no need to burn unto a CD.<br /><br />download this :<a href="http://www.fileserve.com/file/xz4UMec/Win.Pass.reset.7.www.onhurrah.com.rar">http://www.fileserve.com/file/xz4UMec/Win.Pass.reset.7.www.onhurrah.com.rar</a><br /> <br /> Key Benefits:<br /> * Very easy to use, with complete screenshots.<br /> * <span>Reset</span> Any Password (including Administrator).<br /> * Supports Windows XP, XP+SP2, 2003, 2000, NT, Windows XP Professional x64 Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems, Windows Vista, Windows VISTA(64-bit) & Windows Server 2008.<br /> * No need to reinstall Windows (this does not affect your existing installation).<br /> * Resets passwords with a bootable CD - ROM.<br /> * Resets passwords with a bootable USB drive (Windows Password <span>Reset</span> 6.0 Professional only).<br /> * Works on ALL laptops, computer systems, servers and even older computer models.<br /> * Supports FAT16, FAT32, NTFS, NTFS5 file systems.<br /> * Supports All <span>Hard</span> Disk Types SATA, IDE, SCSI. you can free download Windows Password <span>Reset</span> 7.0 now.<br /> <br /> Instructions:<br /> Step1: Download My File obviously<br /> <br /> Step 2: Burn the ISO file to a CD. If you are using a USB drive, then mount the cd080802.iso file to a virtual drive. Open the Virtual Drive and Copy all the contents to your USB disk. If any error comes while copying just skip the file. Now to make the USB Drive Bootable open a Command Prompt(Press Start + R, Type cmd and enter) and type the following commands:<br /> <br /> Sl.No. Command: Action:<br /> 1 j: Enter<br /> 2 syslinux.exe -ma j: Enter<br /> <br /> Here j is my drive letter, you should enter your own drive letter.<br /> <br /> Step 3: Now start the System which you want to <span>reset</span> the password by putting the CD or the USB in the Computer. While start up you have to make sure that it boots up from the correct device i.e. from the CD or the USB. In order to do this go to your BIOS settings and change the boot order as CD or the USB drive as the first option. Or if you know the Boot menu key then press it and Boot from the correct device.<br /> <br /> Note: Step 4 to Step 8 takes a very less amount of time. No need to worry!<br /> <br /> Step 4: After booting from the CD or the USB, press enter to continue the boot process. In the first step it will automatically select the disk where your windows is installed. Simply press enter to continue. In the Second Step it Will select the path and registry files. Select 1 for password <span>reset</span> (It will select 1 by default, just enter).<br /> <br /> Step 5: Now after selecting the paths, It will ask "What to do?" Simply press enter as it will automatically select 1 for Edit User Password.<br /> <br /> Step 6: It will show a list your system usernames and their password status. Now enter the username whose password you want to <span>reset</span>. It is case sensitive so, be careful and type what you see in the users list. (If the user is Administrator just press enter as it has already selected Administrator by default otherwise enter the correct username)<br /> <br /> Step 7: It will show you User Edit Menu. Select 1 to clear the user password.<br /> <br /> Step 8: It will clear the password. Now Enter "!" to quit from the User select menu. It will again ask "What to do?". enter "q" to quit. Now in step four it will ask you to write the files or not. Enter "y" to write the files. It will write the files back. Now Simply press enter when it asks for "New run?" as it has selected no by default. The password <span>reset</span> has been successfully completed. Press the power button.<br /> <br /> Now start the computer and you will find that it is not asking for password for the user you had selected. That's it, you are done.<br /> <br /> <b>NOTE: TESTED ON XP,VISTA AND 7<br /><br />i hope it will help you ,thanks for trusting fixya...<br /></b>
on Feb 12, 2011 | Computers & Internet
Tip
How to recover lost PDF Password
What can you do if you have forgotten password for PDF protected file,it appears"Enter the password".You don't have the password .So how to decrypt password protected PDF Files?
SmartDoctor has released PDF Password Recovery 5.0,software said to recover the passwords of protected PDF documents,even when unusually complicated or long.Successfully unlocked documents are accessible without printing,copying or editing restrictions.
The program supports all character encodings, and can recover passwords entered with any input language or keyboard layout.It is easy to use
1.Click "Open" button of the File Name to browse the full path of the PDF file.
2.On the "Recovery" tab, select "Brute-force Attack (Trying All Possible Combinations)".
3.Click "Start" button in the Menu to initiate the program
4. Some time later, a message box pops up to you, showing the User Password expected. Click "Remove All Passwords from the File" to remove all the restrictions placed on the PDF file. Click "OK".
on Apr 29, 2010 | Computers & Internet
How can I copy and paste a PDF image on my Acer Aspire E1-571
You need Acrobat. Not just Reader to extract and edit PDF files. Plus you could also just do a print screen. This may the easiest, but quality may suffer. gl
Jan 29, 2013 | Acer Computers & Internet
Password rest problem quickbooks pro2008
try the suggestions given at this site
http://support.quickbooks.intuit.com/support/Articles/SLN41478
Dec 09, 2011 | Intuit QuickBooks Pro 2008: Windows
How to down load nimbuzz to my phone so that i can chat on facebook?
Open this website on your mobile phone browser
http://m.getjar.com/mobile/6865/nimbuzz-for-sony-ericsson-w595/?l=ru
Hope this helps
Jun 26, 2011 | Sony Ericsson Walkman W595 Cell Phone
I want to "lock" the flash drive with a password.
    Encrypt Individual Files and Folders on a Flash Drive
  1. Step 1 Choose "Tools" from the menu bar at the top of the program, such as Microsoft Wordmag-glass_10x10.gif, and pick "Options."
  2. Step 2 Select "Security" from the many tabs displayed in the new popup window. Create a password in the "Password to Open" or "Password to Modify" section and click "OK" at the bottom of the box.
  3. Step 3 Confirm your password when prompted. Drag the password protected files to your flash drive. To open a protected file, enter password when prompted. Remember, passwords are case sensitive.
  4. Encrypt Entire Flash Drive
  5. Step 1 Download and install the freeware program "Cryptainer LE" onto your PC or laptop. Enter a meaningful password from 8 to 100 characters and define the file location and size, which you can change at a later time. Enter your password when prompted.
  6. Step 2 Install Cryptainer Mobile when the Cryptainer LE installation is complete. Select "Tools" on the menu bar at the top of your screen. Select "Install Cryptainer Mobile" and follow the prompts. The Mobile version comes with the LE download.
  7. Step 3 Close the LE version on your desktop. Select a location and meaningful password for the Mobile version. To protect important files and folders, drag and drop them into the vault, the location of the encrypted files.
Jun 24, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I am looking for parts for the Acme 6001 Juice
Just google Acme juicer parts. The new lids are a tight fit and
have to be filed down if you're handy.
May 11, 2010 | Acme 6001 Juice Extractor
My computer has a password in the BIOS Setting. i forgot it
Do you know what the password is? If so, enter the bios and change it. When asked for a new password, just hit enter. If it asks a second time to confirm the password, just hit enter again.
Good luck
Mar 17, 2009 | Dell Inspiron 8600 Notebook
Royal Marines Commando - Windows for Windows, DOS Logo
Top Royal Video Game Consoles & Games Experts
James Wishart
Are you a Royal Video Game Console and Game Expert? Answer questions, earn points and help others
