Had new fuel filter , prime pump and pipe from filter to prime pump
SOURCE: Vauxhall Vivaro Van 53 plate. Wipers not Parking
hi i have the same problem...can you tell me if you have an answer yet???
SOURCE: my vauxhall vivaro van gear salecter has problem sellecting 1st 2
slave cylider is prone on this van the gear box has to be removed and new clutch fitted as the cylinder leakes fliud in the box get ride before it goes completly it is a very costly job!!!!!!!!!!! thanks jezza
SOURCE: vauxhall vivaro wont start cold
Sounds like a faulty cold start assistor. On top of the engine you will find an aluminium housing with four things that look like glow plugs screwed into it. These 'glow plugs' are only available complete with the housing fron Vauxhall. Approx £70 +
Airbag light is probably a fault with the seatbelt pretensioner.
Check the wiring under the seats for damage or perhaps the plugs have pulled apart.
SOURCE: i have red stop light on my dashboard within a
This is your check engine light, signaling and warning you to check your engine.It could be anything ranging from a loose gas cap to a multiple cylinder misfire to an evaporative emission concern.Your best sure bet will be to have it scanned by a shop or invest in a scanner yourself and investigate the code yourself.Hope I could help..
