Question about Boynq Cubite Computer Speakers
Boynq Cubite Computer Speakers usb ports unrecognized
  • Boynq Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
Posted on Feb 15, 2012
Unrecognized usb ports
If you have pulled too much curent through a USB it will be shut down. A restart of the computer should bring the port back-leave whatever you had plugged into the port leave disconnected.
Mar 12, 2014 | E-Machines eMachines Desktop PC
Usb port flash drive unrecognized but broadband is ok before it is working suddenly its stop
plug your flash drive in to a different usb port. if it's still unrecognized try it on another laptop or comp. if the result is still the same then your flash drive is faulty.
Jan 08, 2014 | Lenovo 3000 Y410 Notebook
When this Boynq 841905 Cubite PC speaker is plugged in it seems to disable the USB port on the front of my PC where my wireless adapter is plugged in. If I unplug the speakers USB connection in the back...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps don
Mar 13, 2011 | Boynq Cubite Computer Speakers
I have a intel atom D410PT board. Most of the time my front 2 USB ports never recognise any USB devises. It always says unrecognized device. The 4 USB ports on the back working fine.
Have you reinstalled you computer lately ? If so make sure that all your drivers have been installed correctly. If so that would mean that you have a hardware problem with the USB controller (translation dead USB ports). If you are able to check to make sure that all cables are seated properly. If you are not comfortable doing this ether ask a competent friend or find a small computer repair facility they will most likely be able to help.
Feb 28, 2011 | Computers & Internet
When i input it into the computer it is coming up as unrecognized i have tried rebooting i have no clue clue please help i have all of my important info on this usb
try unplugging all other usb connected to your pc (except the mouse and keyboard if it is connected to usb port). try to plug it at the back usb port of your pc.
Oct 21, 2010 | Computers & Internet
When i insert pendrive computer says unrecognized device
you might have to install usb drivers
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers
hope this helps
Oct 19, 2010 | Microsoft Computers & Internet
Unable to install drivers for my Boynq Alibi Webcam
I had the same problem, I bought it from a store with no CD! After plug the USB i have only sound with no Video.
After googling around i finally found the solution: You can try below.
1, Unplug your USB connector
2, Download the right driver from the real manufacture : http://home.eeti.com.tw/web20/drivers/IC_drivers/PCCAM_WHQL_Standard_Installshield_120308.zip
3, Unzip and install the driver.
4, After finished installation, replug the USB connector (You should plug to the different port that you used to plug before)
5, Now window XP finds the right driver and installs for you.
6, Restart your PC, then use Skype to test. It works :)
Hope this help you guys
Good luck
Dec 10, 2008 | Boynq ALIBIAIR Webcam
LS2208 scanner unrecognized by my HP notebook
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
Aug 05, 2007 | Symbol LS2208 Handheld
Corrupteed and Unrecognized Device
if this is your first attempt ever at this particular MP3 and pc link, is it possible the dell device is a USB 2.0 required port while your pc is limited to USB 1.0?
May 31, 2007 | Dell DJ Ditty MP3 Player
Boynq Cubite Computer Speakers Logo
137 people viewed this question
Top Boynq Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Boynq Audio Player and Recorder Expert? Answer questions, earn points and help others
