Question about Hotpoint Aquarius WMA42 Front Load Washer
What is drum size for hotpoint aquarius wm63 - Hotpoint Aquarius WMA42 Front Load Washer
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
  • 225 Answers
SOURCE: How to cahnge carbon brushes
The brushes usually "come complete with brush-holders", which is a way of selling you something extra that you don't need. Easiest way is to disconnect the machine from the power and the water, turn it onto its front on an old cardboard box and remove the motor from its mountings on the washer. You can usually get acces to one of the brushes really easily and the other is guaranteed to be a real pig, so keep it simple. The brush-holders are usually fastened to the motor casing with either self-tapping screws or small bolts.
I buy my brushes from Ebay sellers and always send them a digital photo of the old brush together with the make and serial number off the motor itself, just to be sure. Brushes can look similar and be that silly millimetre too short, or long, or wide.
Did that answer the question? If not, add a comment and I'll expand further as necessary. Cheers, D.
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: hotpoint aquarius drum makes a noise and is stiff at one point
You take the top off. A couple of screws on the back of the unit, then the top slides off backwards
Posted on Oct 23, 2008
  • 82 Answers
SOURCE: Hotpoint Aquarius 1100 WM63. fills with water...I
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Posted on Jun 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to take bearing out of aquarius model wm63
The information for dismantling and rebuilding a Hotpoint WM washing machine is all in the workshop manual including wiring connections
Mar 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Rattle on fast spin
Hi mate the rattle could be caused by a coin are a bra wire regards a coin you would have to take off the main pump hose connected to the drum our else take the heater element out and see if you can find it if it is a bra wire just rotate the drum until you see it and pull it out
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Changing belt
the belt seems to be too short, how can i get the belt on the motor and the pulley on the drum?
Mar 29, 2008 | Kenmore 44072 Front Load Washer
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
