Question about Hitachi Heating & Cooling
RAR-2P2 setting date month etc
Have loaded new batterys now controle will not reset
2 Suggested Answers
SOURCE: BROKEN/MISSING HITACHI AIRCONDITIONER REMOTE CONTROL rar-2p2
abhay .hi their is a problem in my remote
Posted on Feb 08, 2010
SO GUESS I NEED SOMEONE TO RESET MY CONTROLLER
If you are referring to a remote control, it is "reset" by removing batteries, pressing all buttons to eliminate possibility of a stuck one, installing new batteries, and testing operation.
Jul 18, 2016 | Televison & Video
ITS READING MESSAGE BATTERY SAVER ON
Your probably going to need to take to a dealer for this , I don't how much you know about modern automotive charging systems . Plus it would help to have a professional scan tool ! The charging system on you vehicle is computer controlled ! The engine control module (ECM) controls the generator through the generator L-terminal control circuit. The signal is a 5-volt pulse width modulation (PWM) signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-95 percent. Between 0-5 percent and 95-100 percent are for diagnostic purposes. The following table shows the commanded duty cycle and output voltage of the generator:
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to for load shed 2 setting criteria.
The electrical power management (EPM) system is designed to monitor and control the charging system and send diagnostic messages to alert the driver of possible problems with the battery and generator. This EPM system primarily utilizes existing on-board computer capability to maximize the effectiveness of the generator, to manage the load, improve battery state-of-charge (SOC) and life, and minimize the system's impact on fuel economy. The EPM system performs 3 functions:
It monitors the battery voltage and estimates the battery condition.
It takes corrective actions by adjusting the regulated voltage.
It performs diagnostics and driver notification
Load Shed 2 Start
Less Than 10.9 V
Battery has a net loss greater than 12 AH
Rear defrost, heated mirrors, heated seats cycled OFF for 50% of their cycle. The BATTERY SAVER ACTIVE message will be displayed on the DIC.
You have a charging problem or battery problem !
Feb 27, 2015 | 2006 Chevrolet HHR
Power,starting,charging issues after installing new headlights last week,i disconnected the battery to install new lights and reconnected it,later that evening i went to start my truck and it just clicked,...
run the fault codes first to see if there are any codes, next is to use the scanner to reset the ECM program
Lastly is to check the wiring circuit to ensure that you have not by-passed a control that stops the battery from going flat.
Lastly have a load test done on the battery because the gauge shows full voltage , batteries can fail under a load such as starting.
Feb 20, 2015 | 2003 Dodge Dakota Club Cab
How do i reset this remote....display is blank and buttons not responding - new batteries installed
there is no reset once the new batteries are installed the display should come up. are you sure the new batteries are fully charged? are they in the right way?
Jun 06, 2014 | Samsung Remote Control DB93-03012G...
Reset Cruise Control
use a code reader to reset the CPU program as battery replacement often corrupts the program
Mar 14, 2014 | Chevrolet Cars & Trucks
1993 buick roadmaster won't start. 12.6v at the battery, less than 10v on the dash voltmeter.
I should think that you tested the battery voltage with a multi meter and you would expect 12.6 volts . However if you test a battery use a load tester that simulates the battery under load as from a starter and you would find that the 12.6 volts drops to the red zone . have a load test done on the battery and you will probably find a faulty cell
Feb 19, 2014 | 1993 Buick Roadmaster
Utilitech wall timer
Utilitec timers do not have replaceable batteries.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
http://waterheatertimer.org/ST01C-program.html
Add a comment
Jul 18, 2013 | Hardware & Accessories
Timer wont turn on
Add a comment and include timer brand and model, or describe timer in detail.
Is timer plugged into outlet? Or harwired?
Does outlet have power?
Is circuit breaker ON?
Is this new timer, or old timer that stopped working?
Reset timer.
Change battery?
What load is being controlled by timer?
Mar 29, 2013 | Hardware & Accessories
2003 Ford Focus battery light is on, but alternator appears good
Disconnect battery ground for 30 seconds & reconnect. Light should be out unless you have deeper diagnostic problem. Charging system good Battery good. This action should reset trouble light. Good luck!
Dec 29, 2009 | 2003 Ford Focus
What does the ''Reset'' position on the ''Load Size'' knob do?
if you have filled machine to say small water level and change your mind you turn to reset and then set your new level hope this helps
Nov 06, 2009 | Coffee Makers & Espresso Machines
Heating & Cooling Logo
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
