Question about Fisher and Paykel Washing Machines
Fisher and paykel smartdrive motor
Hi, I have one of these machines which is playing up. It is failing to fill (Fills intermittently for a minute then stops with error code) then if manually advanced does nothing. The lights which come on for the fault code are one and five, which appears to relate to the motor. I have rotated the agitator and drum by hand, it almost seems to get going sometimes but doesn't. What is my most likely problem and what will it cost to fix it? Thanks!
  • Fisher and P... Expert
  • 554 Answers
136. (10001000) Phase 1 to 6 - Motor Stall
The Motor Controller has been unable to start the motor. Possible causes of this
fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals,
faulty Motor Controller module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action:
Measure / check the motor harness, connectors and motor for discontinuity. This
can be done by taking a resistance measurement between phases of the motor
harness at the Motor Controller module end. Nominal resistance should be around
12.2 ohm for Phase 2,3 & Phase 4. For Phase 5 and 6 onwards the nominal
resistance should be around 32 ohms.
Secondary Source: Motor.
Action:
1) Check free rotation of the agitator and basket by rotating by hand. Bearings
and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for water,
mechanical damage or corrosion.
Tertiary Source: Motor Controller module.
Action:
If the primary and secondary checks pass inspection then replace the Motor
Controller module.
Posted on Dec 26, 2013
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: fisher and paykel smartdrive lets water in in spurts then stops
might be an overload. remove some clothes and retry. I have the manual here on my site:
Use the sire search to find it
http://sites.google.com/site/sublimeappliancerepair/Home
Posted on Aug 31, 2009
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
good luck
Jul 06, 2010 | Washing Machines
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
HI. I have an old F&P Smartdrive 085 and I am looking for the reset button on it. It was not completing the cycle and wouldn't turn off so I turned it off at the wall, waited for a while and turned it...
sounds like your motor controller is faulty.the sharp click u heard was the fuse on electronic board popping. unfortunetly there is no reset button. u might need a new controller.if u r not comfortable working with electronics it would b best to ring a repairer in your area. please reply 4 more help
Mar 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel smartdrive lets water in in spurts then stops
Aug 31, 2009 | Washing Machines
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
41 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
