Question about Epson DFX-9000 Matrix Printer
Error 04 dfx-9000
Wath i ca do when i have this error 04 for printer epson dfx-9000
    Novelist:
    Scholar:
  • 95 Answers
Well, first things first, you should go into the control panel, open hardware, then device manager, highlight "printer" and then scan for hardware changes, if no recent changes were made, you should check if there was any "Driver updates and changes" and see when the last change/s were done. If it's not a updated driver, then it's probably a recently update to the program. if neither are relevant you can "roll back the driver". Word of warning, although it may solve the issue, it can also make things worse. Be sure to make a restore point before you start this (System Restore). Make sure it's turned on before you start any changes. If it's turned off, activate it and select "make/create a restore point" just in case. If it's already on, pick the oldest restore point you have and use it, that often fixes things. You can also try uninstalling the printer program and re-installing it, that can work also. If none suggestions work you could go through the instruction manual and see if they have any suggestions. I've included a link to the it for you. Just copy and paste into the address bar. Hope this helps. Grim
https://files.support.epson.com/pdf/dfx9k_/dfx9k_ug.pdf
Posted on Nov 03, 2014
    Scholar:
  • 51 Answers
Fatal Error Code 04: PF Driver Error
The Mechanism Control ASIC detected either:
  • Abnormal current to the LF motor
  • A single phase of the LF motor was energized longer than the allowed period of time
Either the driver, motor, or both have malfunctioned.
Refer to the Service Manual, which is available at:http://www.scribd.com/doc/48366084/Epson-DFX9000-Service-Manual
Hope this helps!
Posted on Feb 14, 2012
ohms
  • 1879 Answers
SOURCE: PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Posted on Sep 11, 2008
Inky
  • 691 Answers
SOURCE: error 07 ,turn off Printer on dfx 9000
The motor (+42 V) or head drive (+37 V) voltage fell below the
allowable level.
This error indicates a power output problem, or a voltage detection circuit failure.
Check and replace the following in the order below, checking
functionality at each step:
Power Unit
ROM Board
Posted on Jul 23, 2008
ohms
  • 1879 Answers
SOURCE: epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Posted on Jan 22, 2008
ohms
  • 1879 Answers
SOURCE: Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Posted on Nov 20, 2008
SOURCE: I need help with solution to error 0E in Epson DFX
you have 2 posibles options one of them is the ribbon cable or mainboard, the most probable is the mainboard is damage. If you find one mainboard good and cheap e mail me, i am looking for it.
Posted on Oct 02, 2009
How to solve error 04
Hello muhammad wasif
Have you determined exactly what type of error 04 is describing for your Epson DFX-9000 Matrix Printer by reading your owners manual?
Is it possible to attempt turning off printer, then turning back on.
This possibly could remove trouble code error 04.
Dec 27, 2011 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Error 16
try uninstall printer ,, then reinstall it,,, (if you have cd for it!) if not got to epson and dowload the driver files needed
Aug 12, 2009 | Epson DFX-9000 Matrix Printer
Error13 for epson printer dfx 9000
ALLO CHO MINH HOI MAY IN KIM EPSON DFX 9000 BAO LOI ERROR 03 LA BI PAN GI VAY ?
Mar 18, 2009 | Epson DFX-9000 Matrix Printer
Nov 20, 2008 | Epson DFX-9000 Matrix Printer
Error 07 ,turn off Printer on dfx 9000
Timing fence could be faulty or dusty. Clean it and test if that fails replace it.
Jul 23, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
Jan 11, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
662 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
