Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
How do you align the infuser up right of the delonghi perfecta cappachino machine
Cant squeeze 2 red clips in together as right side is to hidden , the infuser needs to be in the upright position to be able to do this but i can get the infuser to stand upright !
ginko
  • 19396 Answers
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
Posted on Aug 20, 2008
SOURCE: infuser will not come out, can anyone help?
the infuser is tilted and I cannot get it back to center
Posted on Dec 09, 2009
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
  • 4 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Posted on Feb 08, 2011
mnwarfield10
  • 452 Answers
SOURCE: delonghi magnifica rapid cappuccino model EAM
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Posted on Feb 27, 2011
Capuccino button has fallen inside panel
look up parts diagram DeLonghi Perfecta ESAM5500 download file, this will give you idea what needs to be undone and how to undo,often a combination of un-doiing screws and finding and locating hidden clips and disconnecting ,if button fell behind panel probably something has also broken that holds button in place .
Aug 18, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The infuser seems to be stuck to the side and I cant get at the red release button on the right hand side
Put back together, turn on the machine, then turn of the machine with the power button on the machine, then turn of the power point, should be back in place to push in both red buttons, enjoy your working machine and coffee, cant find an answer for my issue
Jan 02, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Impossible to remove infuser, appears to be jammed
Plug in Machine. Turn on for 10 seconds or so. Turn off. Let Machine turn itself off completely. Once it is quiet, do not unplug, try to remove the infuser. It worked for me (procedure recommended by customer service for Delonghi in Switzerland).
Oct 23, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Magnifico eam3200 series...centre piece jammed
I have a perfecta and found that the mechanism that translates the infused up and down was jammed. I unplugged it and removed the back panel - two phillips screws - then you will see the motor and cog belt -BE SURE UNPLUGGED - I then turned the motor shaft using my index finger against the cog belt and with the access door open I could see the infuser translate down to a park position. I took it through an entire cycle which actually retracted the infuser and actuated the coffee grind sweep arm - there is a horizontal feature that looks like a sideways 'L' that seems to be a reference for the park location - since when the top of the infuser was at this mark the infuser unit could be removed and the infuser was in the compact configuration as described in the user manual. I am getting a general alarm still and would like to know if anyone could point me to an electrical schematic and functional sequence block diagram.
Oct 16, 2007 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
105 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
