Question about Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet
I purchased my toilets just 4 months ago. One works fine and the other doesnt. When you flush it it goes down, but filling up takes approximately an hour. I have the water valve turned on full and I tried adjusting the screw which made no difference. Please tell me what to do?
tbirdfan1
  • 3051 Answers
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
Posted on Jul 19, 2010
Nomodo4u
  • 863 Answers
SOURCE: my jacuzzi toilet won't quit filling, I have
You gonna have to replace the whole fill valve mechanism. Go to the hardware store and get the Korky brand, because they work like a champ and they are super quiet. Don't buy Fluid Master because they clog easily and are junk. Learned that the hard way after having to 3/4 of them on a 42 unit apartment complex.
Posted on Oct 12, 2010
woobie dog
  • 1273 Answers
SOURCE: my jacuzzi toilet doesnt fill with enought water
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Posted on Jan 29, 2011
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
TOILET DOESNT HAVE A GOOD FLUSH PRESSURE AND DOESNT FILL FAST ENOUGH
Valve needs adjustment (Small screws on top) or replaced. tank ball rod bent or turned down.Depends on model.
Mar 17, 2012 | KOHLER Revival Two-Piece Elongated Toilet,...
I have neptune parma toilet, which was purchased 6 months ago. It was working fine but now it has a problem with filling up. It takes a minute before it will start filling up then it makes noise like...
This is usually the fill valve. Try adjusting the water height. If that doesn't work, you can replace the fill valve fairly inexpensively with a new one at any home improvement store
Aug 27, 2011 | Neptune FB1625 Parma Toilet
We bought a Kohler Cimarron complete solutions 2 pc. toilet about 2 months ago and now it doesn't want to flush properly.The toilet fills half way up with water instead of just wooshing down like it...
Before taking it out you need to go back to Lowe's and purchase a toilet auger....
With this you can crank it down through the trap of the toilet and remove the obstruction...there is something in there that a plunger will not remove...example...a pen or pencil... comb...these are commonly removed when I het the symptoms you are giving...
heatman101
Aug 13, 2010 | Kohler Cimarron Comfort Height elongated...
Toilet takes vey long to fill the tank.
More then likely the power valve in your flush master ball valve is out.. Replace flush valve and should fix problem. Home depot sell fluid master for like 7.50
Mar 02, 2010 | Kohler - Toilet - Two-piece - Highline -...
Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet Logo
56 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
