Question about Boating
How to replace 9.5 evinrude impeller
Evinrude 9.5 hp
3 Suggested Answers
  • 86 Answers
SOURCE: how to replace impeller in a 1959 evinrude
Put engine in fwd gear. Then disconnect the shift linkage. Remove the bolts that hold the gearcase on and slide gearcase off of the tower. Remove the 4 bolts or screws in the waterpump housing and lift the housong off. Replace the impeller and reassemble in reverse order. Make sure that you get the water tube lined back up and you can twist the prop to line the splines back up in the powerhead.
Posted on Aug 09, 2009
  • 43095 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
What is the year of my 4 HP Evinrude Model E4RETB, S/N 08966530?
E= Evinrude
4= HP
R= Rope Start
E= 9 INTRODUCES
T= 3 1-2-3-4-5-6-7-8-9-0
B= Specific Production Model
Sep 25, 2014 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
Apr 24, 2010 | Boating
Boating Logo
166 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
