Question about Saws
Rip capacity is too small (24
Would like to replace the rails and fence , to provide moore ripping capacity if pallible but havn't found any replacements out there , do they make such an accessory for this saw. (50"fence/rail and table and legs)(
    Genius:
  • 1,212 Answers
If you can locate an old Delta Fence, I have seen those transplanted to a number of other table saws quite easily and reliably.
Otherwise aftermarket, there is the Beismeyer fence, it was adopted by Delta and licensed. You can get them through Delta or even Amazon. There are other vendors. You will want to add outfeed tables and extension tables as well.
You did not indicate which saw you have, but in general terms this applies to most saws.
Posted on Feb 15, 2012
Idaho_Biker
  • 32 Answers
SOURCE: Fence won't lock on rear rail.
Before I can assist You, I need you to provide some more Information.
Make, Model, & Serial # of Table Saw? Is this Fence the Standard that came with the Saw? What type of "Rear Rail" do you have? What "Rod" are you referring too?
Posted on Apr 10, 2009
  • 9 Answers
SOURCE: my handle broke off on my hitachi table saw c10ra3
go to garage sales and try your luck. ive had the same problem with differant brands and had to replace the whole thing. check manufacturers web site or your owners manual and see if its a replacable part with a part#
Posted on Apr 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a craftsman table saw 113.27520. Probably a
I checked Searspartsdirect.com and most of the parts for this saw are obsolete no replacement. You might want to go to the site and double check for the part that you need,
Posted on Dec 13, 2009
  • 10 Answers
SOURCE: after moving the table saw to a new residence i
I am guessing it must be damaged beyond the adjustments. Are you sure the blade is aligned with the table? If not that could be the problem. I have most rip fences for craftsman belt drive saws available, Ebay 'Hokienpokie" or contact me via email, if you need another fence. Jim
Posted on Feb 12, 2010
rowdy45176
  • 2176 Answers
SOURCE: rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Posted on Jul 18, 2010
Adjust the tighting arm on shop fox fence
You can find the manual here:
http://tinyurl.com/oraxzup
The parts for the rip fence are on page 16.
Oct 20, 2014 | Shop Fox W2006 Classic Fence w/Long Rails...
Table saw blade alignment
Are you referring to the table top or rip fence alignment? The blade itself is not aligned. We adjust the table to parallel with blade and the rip fence should toe away from blade 0.01mm over the length of the rip fence to prevent binding.
Jan 14, 2014 | Delta Saws
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 | Delta Saws
Manual for sears table saw model number 113 29940
I found a link to a manual for the rail and fence system if that helps:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0060111.pdf
Aug 03, 2012 | Saws
Rip fence is out of alignment..what do I need to do?
This is the fundamental problem with rip fences on table saws. I don't know what kind of rip fence you have, but most rip fences are adjustable for squareness. However, unless you have a very nice (and expensive) rip fence, they often don't self-align when you move them anyway. If you have the type that clamps at the front and the back of the table, the problem can be overcome by making sure the rip fence is straight before you clamp it in place. The easiest way I have found to do that is to use an adjustable square. Put the front of the rip fence where you want it, then set the adjustable square so that it matches the distance from the miter slot in the table to the fence. Then move the square to the back of the table and move the back of the fence to meet the end of the square. Now clamp it in place and check the front and the back one more time. It's tedious to do this every time you adjust the fence, but you can get a perfectly aligned fence this way. This method assumes that your blade is parallel to your miter slots, which is adjustable too, but you have to get underneath the saw to do that. good luck, Al K
Jan 14, 2011 | Saws
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
Need fence for radial arm saw
Most guys will attach a sacrificial particleboard sub top about 24" deep (per model) then towards the back of the saw attach a 3-4" square particle board rip, screw it down, then attach a 5/4 to 6/4 square maple fence approx. 4" tall and attach that to the 3-4" wide rip of particle board. then place a additional particleboard top in front of the maple fence. That will give you a 3-1/4" tall fence. all you would need to do is sqare it to the blade and attach it to the saw. Hope this helps
Nov 12, 2009 | Delta 10" Radial Arm Saw
Saws Logo
98 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
