Question about Toshiba Satellite (K000004080) Motherboard
Toshiba dc connector
The dc connector on my toshiba laptop broke. Do i need to replace the whole motherboard or is there another solution?
  • hopeisback Oct 25, 2008
    I would actually have a computer repairer fix it but the guy I called said that the motherboard would need replaced. So it can be soldered back on?
    Brigadier General:
  • 6,966 Answers
If the laptop still works, then there would be no need to replace the motherboard. The DC jack is replaceable/repairable. What would be more challenging is the disassembly and eventual exposing of the bottom part of the circuitry where the DC jack is soldered into. Often the DC jack would have at least 2 solder point (not more than 3). This might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 25, 2008
  • Louie  Role
    Louie Role Oct 25, 2008
    If the laptop still works, there would be no need to replace the motherboard. The DC jack is usually just soldered on to the board.
No start after reassenbly to clear cooling fans. lights come on. no fans when start is pushed no action at all.videoed disassembly to insure correct re assembly according to toshiba A75-S2131 specs by
A) You did use an ESD wrist strap, and have it's alligator clip attached to a good ground source, right?
That way you don't have to worry about Static Shock issues, and frying out your laptop.
No?
You may have an expensive paperweight now.
(Although the motherboard does make a pretty good Frisbee)
Use any type of Anti-Static Precautions?
You did Follow Anti-Static Precautions? Good. Let's go on.
A) DC Power Jack
http://www.ebay.com/itm/DC-JACK-POWER-PORT-TOSHIBA-SATELLITE-A75-S2131-A75-S206-A75-S2061-A75-S276-/270935761721?pt=Laptop_Adapters_Chargers&hash=item3f1507a339
Not advertising, using for reference. (Photo views)
1) Battery removed check the Center Pin of the DC Power Jack. Does it move?
2) Cracked solder joints of DC Power Jack to motherboard?
Yes, means disassembly again to check.
B) Cables (Wires) are routed SPECIFICALLY through Channels and Latches.
1) Are they, or is one or more pinched by being in the wrong place?
C) Power On button board's FFC installed, in the SAME direction as when it came out? Lock Bar in place to keep FFC locked in?
FFC = Flat Flex Cable.
As you know it has no connector on the end. The motherboard has the ZIF connector. Zero Insertion Force.
http://en.wikipedia.org/wiki/Flexible_flat_cable
The flat contact pins of that FFC has to line back up in the ZIF connector on the motherboard, the same way it was when removed.
Broke the Locking Bar on the motherboard's ZIF connector, or the Body of the ZIF connector?
You're looking at motherboard replacement.
Post back in a Comment with your findings.
Regards,
joecoolvette
Aug 17, 2012 | Toshiba Satellite Computers & Internet
The power connector on my Toshiba A60 PSA60U019VOIE motherboard broke off, so I cannot charge the machine. Everything else works on the mahince. Can I solder a new connector on the motherboard
Yes, a new connector can be soldered. First you have to disassemble the laptop and remove the motherboard.The following links would give you all the details/ instructions with picture
1. Dis-assembly guide
2. Maintenance Guide A60
3. DC JACK REPAIR
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Toshiba Satellite A60 Notebook
The inside power plug for Toshiba laptop is broke. The estimated cost for replacing the plug is $300.
Or, for $399, you can go to Walmart and get a new Toshiba laptop.
The reason it costs so much is the labor involved. To repair this break, it literally requires a complete disassembly of the laptop, replacing and soldering on the connector, then reassembling the laptop. Laptops, unlike desktops, were not made for easy service, due to the fact that they're trying to pack 10 pounds of stuff in a 2 pound box, for lack of a better analogy.
It's a lot of work to fix it.
Jul 06, 2011 | Toshiba Computers & Internet
Socket of my laptop has broken where we connect our power supply..still we can charge it if we connect through some angles....if we need 2 change the whole board..or can replace the socket only...how much...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
DC connector loose in laptop,no power in the laptop
Apparently the DC connector broke. If the warranty is still in operation, have it repaired; else, the damage can be easily fixed by any electronics shop, or even by yourself if you're familiar with a soldering iron for electronics. This guide is for a different model, but the DC section is practically the same in all laptops:
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
Sep 01, 2010 | Acer Aspire 55421462 Notebook
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
My charger does not power up my Toshiba Satellite A305, is it the motherboard?
Have you tried running it without the battery?
  • If this works, then the battery has died. Replace it or run on p/s alone.
  • If not, and the power supply is definitely working, then the laptop itself needs repair.
Apr 07, 2010 | Toshiba Satellite (K000004080) Motherboard
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
Toshiba satellite a25 i was going to change the keyboard and broke the connecter slide off the motherboard. what should i do..
Without this slide the keyboard ribbon cable will not lock onto the motherboard connector and the keyboard won't function correctly.
The connector needs to be replaced, not an easy job, might be easier to replace the motherboard, but this may not be a cost effective solution might be better to buy a new laptop.
The cheapest solution is to connect a USB keyboard to the laptop, but then you need to lug both of these around when you travel.
Nov 10, 2009 | Toshiba Satellite A25-S207 Notebook
Toshiba Satellite (K000004080) Motherboard Logo
433 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
