TH-PZ800A red light blinks
Red light blinks 2 times then pause and repeat
djchillsnyc
  • 151 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
Sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Nov 12, 2012 | Televison & Video
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
May 23, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Mar 12, 2009 | Panasonic Televison & Video
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
