Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Door frame warm
The frame between the two door is hot and there is a smell like melting plastic
  • Whirlpool Master
  • 3,289 Answers
Nearly all modern fridges are self defrosting. Additionally, some models offer the option to minimize moisture on the cabinet. To do both the defrosting and controlling moisture build up, small heaters are used. Defrost heaters are located in the freezer compartment.
Typically, the other heaters are installed in the frame on the front of the fridge cabinet, near the freezer opening. This is where sub-freezing cold air would escape and contact the warmer (room temperature) outer cabinet. This causes condensation much the same way a glass of cold water "sweats" sitting on a counter or table. The warmer and more humid the room is, the more quickly the condensation will form. The heater is used to quickly evaporate any moisture that collects on the cabinet. This heater is operated at the same time as the defrost heater, and they are turned on by a timer, 2 or 3 times a day for about 20 to 30 minutes each time. When they are powered, it is expected that the cabinet will be warm to the touch. You may smell plastic, as the door seals adjacent to and in contact with the heated parts of the freezer opening are warmed, and is normal - particularly if new. The heaters should never be hot to the touch nor should smoke be seen.
I hope this helps!
Posted on Feb 14, 2012
LG side by side Model LSC 26905
Insulation does not melt - gaskets may be affected by hot temps.
Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
Jul 29, 2016 | LG LSC26905TT Side by Side Refrigerator
After driving my vehicle, there is a hot glue type of smell coming from the engine. But as soon as I turn it off the smell goes away. Any ideas?
Sometimes people will run over a plastic bag and it will melt on the hot exhaust pipe and cause to smell.
Aug 16, 2015 | 2004 Ford Freestar SEL
Burning electrical smell, refrigerator hot at lt side (freezer side) and at center area between doors
When you smelt this was the fan in freezer off? If so it is most likely in defrost mode and the smell is from frost melting and hitting the heater in the freezer. The hot on the sides and in the center. Is this outside the box? If so this is normal. There are coils inside the frame of a fridge that stay warm to eliminate condensation. Sometimes they shift and get too close to the wall and thats what you are feeling.
If you have any further questions please feel free to contact.
Jul 27, 2011 | LG LSC26905TT Side by Side Refrigerator
Heated the middle body it smells like a plastic burned
do you mean that the area of the outside cabinet where the door seal presses up against is warm? If this is what your describing then your compressor fan is not turning and causeing the lines to heat up unplug the machine until you are able to replace the fan if this is the issue you are seeing on your unit if not please clarify when you said heated middle body and where the smell of plastic is coming from. also is the freezer and fridgerator still getting cold? You may also want to check the light area I have seen many times where the lights will melt the plastic. If you have any further questions message me back I await your reply Thanks Rick
Jul 04, 2011 | Samsung RS2530B Side by Side Refrigerator
My Daewoo microwave is model KOC-9Q1T/KOC-9Q1TSL I notice that the plastic frame around the top of the door is wrinkled, as if it has melted. I have photos of this if you need them. Please let me know 1....
Plastic will melt but the door frame is metal and will not. So there is no safety issue here, just looks.
One could replace the door assembly if required. I would leave the door open after convection cooking to let the heat escape without heat build up causing the plastic to mishape.
Mar 11, 2011 | Daewoo Microwave Ovens
When running there is a smell of warm of burning wire insulation and the top left side of the door has a warm feeling to it
This could be a sign of a short in the electrical components and power should be disconnected so not to cause any damage to the dishwasher or more important you and your house. The only other thing that I've ever seen make a smell like this, is when something plastic is melted on the heating element at the bottom of the dishwasher and every time it calls for heat, it melts more. Its usually a kitchen utensil or one of the wheels from the racks. Hope this helps.
Dec 27, 2009 | Dishwashers
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
