Question about Intel D915GAV Motherboard
I have installed t sound driver.. but i can hear a constant sound whenever i use it and if i talk over t headfones even the other side who is hearing me can hear the noise also... how can i solve this??
  • Intel Master
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Feb 14, 2012
Samsung intensity 3
LG CE 0168 NO CODE CAN UNLOCK THIS PHONE?
Jun 22, 2013 | Samsung Cell Phones
Whistling sound upon acceleration
Tyres, brakes, turbo, transmission, axle ...
Jul 06, 2017 | 2000 Jeep Grand Cherokee Limited
My headfone ok i can listen other by headfone but my microfone driver not working i wanna update micro fone driver
Hi phool0055 ,
There is nothing as a separate microphone driver that you need to install generally ,
All you need to do is check microphone settings , as to whether they have been changed or the microphone has been muted accidentally.
Please follow the below steps :-
  • In control panel , open sound speech and audio devices
  • The click on the audio , tab where you would find two options , sound playback and sound recording.
  • Sound playback has to do with the sound that you hear , i.e. the headphone sound.
  • Sound microphone has to do with the sound that you record or transmit i.e. microphone.
  • Now you would have two options under sound recording sections, namely volume and advanced.
  • Open the volume and advanced section and check if it has been muted.
  • If it's muted , please unmute it and now you would be able to record your voice or chat using a microphone.
Hope this helps ..:)
May 09, 2011 | Computers & Internet
Whenever i start songs to hear there is a dialogur
goto device manager uninstall sound card and reinstall with a compitable drivers
May 24, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Why I cant hear anything from the headfones?
Check your system sound setting and make sure it is not set to digital out. Assuming head phones are good, make sure WDM sound driver and device manufacturer drivers are not conflicting.
Jul 25, 2009 | Toshiba Satellite L305D-S5895 Notebook
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Sound
go to sound setting and make headfone primary device ..or disable speakers in contol pannel
Jan 11, 2009 | Compaq Presario Notebook
I am not hearing any sound at all though i have increased every volume buttom
You check your system information if sound driver was installed, type dxdiag in your run command. Wait till a tool bar about your system info will appear then check your sound driver if installed. If it was not installed. you have to install a sound driver. Look at your sound card installed and download from internet any necessary sound card driver compatible to your sound card hardware and mother board. Just try this,. I have solved many computers by following this procedure.
Oct 19, 2008 | Compaq Creative Sound Blaster PCI 128...
Headphone not working on the headphone.
Try the headfones through a sterio or something just to see if the headfone itself is not faulty if it is take it back to the shop and get a replacement. Else the socket for the plugin is faulty.
Sep 22, 2007 | Everex StepNote VA4103M Notebook
Intel D915GAV Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
