Question about Vixel VXL Itona TC2341CE Thin Client TC2341F2R4 Network Terminal
I set my resolution too high on my VXL Itona C42 thinclient. Now i'm stuck with no display. how do i get it back to normal?
To Reset the display to 640 x 480 press :- CTRL+ALT+SHIFT+F5
To reset the terminal to factory defaults press :- CTRL+ALT+SHIFT+F9
itona, vxl, reset, factory defaults, screen resolution, display
Posted on Feb 21, 2013
  • ranjith Apr 12, 2013
    i dont no admin password so how to reset admin password
Thin client
It is a network terminal, you don't have to install anything on it...
... but you need an application server to run on your LAN to use it !
Oct 13, 2013 | Microsoft VXL Itona TC4421-XP Thin Client...
Edit desktop Icons Vxl Itona TC3641
log on to administrator than del the desktop files and go to EWF maneger than commit after report its worked
Nov 02, 2012 | VXL Instruments Itona TC3641-CE Network...
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
I have problem in my lg lcd monitor when start computer windows loading then il say out of range 53.5Hz/85Hz. i don't know how to solve that problem.
Sounds like the resolution is set to high which is why that message would come up. When you turn on your computer, keep pressing the F8 button. It will bring you to a menu. Choose "Safe Mode" and press enter. When you get into windows go into the display settings in the control panel. Then go ahead and set the resolution to 640X480. After you do that go ahead and restart the computer and let it boot up normally. That message should go away and once you get back into windows you'll have icons that look bigger then normal. At that point change the resolution to 800X600, if it takes that then try 1024X768 if you want to.
If after you are in safe mode and change the resolution and that error message comes up then you'll need to download the video drivers for your computer and reinstall them.
May 28, 2011 | Computers & Internet
How to reset to factory default
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin.
Hope it helps.
Jul 05, 2010 | VXL Instruments Itona TC3841 Network...
Display defaults
This is normal as the TV can only display at a lower resolution unless you connect it to a high definition TV. Just change the display resolution back to 1024x768 when you are using the laptop's LCD screen.
Apr 11, 2009 | Compaq Presario 700 470024-192 Notebook
Vixel VXL Itona TC2341CE Thin Client  TC2341F2R4 Network Terminal Logo
642 people viewed this question
Top Vixel Computers & Internet Experts
David Payne
David Payne
Are you a Vixel Computer and Internet Expert? Answer questions, earn points and help others
